Properly Reading/Adding ATF to V70 T5 2001
Noie
Year and Model: 2001 V70 T5
Post by Noie »
Before I go adding too much ATF fluid, I wanted to check in with you all here.
I used this method to check the fluid level which is from another post. 1) Car is run for 30+ minutes at highway speed 2) Pull into flat driveway and shift through all gears, staying in each one for 3 seconds. 3) Shift it to Park and let it sit for 2 minutes, then check.
It reads just above the cold mark lettering. Assuming I need to add maybe .25 to .5 liters?
I wanted to add an image of the dipstick, but it will not let me.
Thanks, Noah.
Has thanked: 1610 times
Been thanked: 4065 times
I just went to link to the Volvo manuals online but couldn’t get that to work. Your procedure sounds right but we will find that and post here
On edit…it looks like manuals only go back to 2004 , changed from before?
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
You are checking while IDLING in Park, right? This matches procedure used for my 2001 V70 T5.
Noie
Post by Noie »
volvolugnut wrote: 29 Mar 2026, 07:56 You are checking while IDLING in Park, right? This matches procedure used for my 2001 V70 T5.
Yes, I keep the vehicle idling when I check the dipstick. :D
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
There is a way to check ATF with engine OFF and cold in the AM.
I posted the trick in this forum.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
cn90 wrote: 29 Mar 2026, 17:13 There is a way to check ATF with engine OFF and cold in the AM.
Here it is viewtopic.php?p=441462&hilit=transmissi ... ld#p441462
Also -> Amazon link
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
You need to know ATF temperature. Low mark is full at 40 C / ~105F, high mark is full at 80 C / 175 F. With engine still running, or it will read high.
Transmission is sealed, fluid does not go anywhere, unless you know there's a leak. Don't add anything.
Just so everyone understands, ATF fluid (and antifreeze) expand a lot from ambient to running temperature. So you really need to know the fluid temperature to get accurate fill level reading.
vtl
Post by vtl »
volvolugnut wrote: 30 Mar 2026, 16:11 Just so everyone understands, ATF fluid (and antifreeze) expand a lot from ambient to running temperature. So you really need to know the fluid temperature to get accurate fill level reading.
And because of that you don't have to be overstressed with checking the fluid level up to 0.01 mm resolution with car on the fully leveled machinist table. +/- 0.5 qt it won't even notice.
Post by cn90 »
Actually, you don't need to know fluid temp.
I already proved it in the link posted by @matthew1 above.
Do this experiment:
- Measure ATF exactly as factory manual, engine HOT and Running on a flat surface. Let's say it is at Max.
- Next morning in AM with engine COLD and Off, measure it.
And...you will see...
