I have Vida 2014
how do you test a component? For example If i wanted to test the VVT selonoid how does one go about that?
I tried last night. I went into diagnostics, got the network displayed, clicked on ECM and went to the VVT in the dropdown. It displayed the VVT diagram and explained what tests are performed, however I saw no way to actually run the tests in VIDA.
any help is appreciated
question on testing
- Grantkat
- Year and Model: 1999 s70 GLT
- Has thanked: 59 times
- Been thanked: 54 times
1999 S70 GLT ~193k
2014D VIDA/DICE
2007 Jeep Wrangler Unlimited ~ 315K
2008 Lincoln MKX ~130k
2008 Toyota Sequoia ~ 252k
Powered by coffee, stripped bolts, and questionable decisions.
2014D VIDA/DICE
Vova585
- Has thanked: 228 times
- Been thanked: 238 times
Do you have an actual issue or it is just a fun project? I will not pretend that I know much about Vida or where to find special functions for it. In any decent aftermarket scanners under special functions you will be able to command vvt solenoid on/off. Vida should have that option as well, but i am not a person to ask where to find it. If you are trying to troubleshoot specific issue, we hopefully can help you more
- Grantkat
AT the moment no I do not.I had a code for VVT but has yet to reappear. I have a decent scanner with control functions in it, however I also have Vida and want to use it since it is very volvo centric. I also know that potentially vida has more functionality.
i saw a post where a vida user outlined how to do it but i could not get it to work.
1999 S70 GLT ~193k
2014D VIDA/DICE
2014D VIDA/DICE
- 17 Replies
- 2209 Views
- 681 Views
- 19 Replies
- 3639 Views
Last post by amblerman
- 4264 Views
Last post by precopster
- 382 Views
Last post by combatkarl
