95 850 electrical wiring questions: chassis grounds, steering column ground, etc
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
I am going to attempt checking all the grounds I find to fix the crazy electrical issue. I found three. They're good. There are two chewed wires that I trimmed (pictured below). Is there a diagram with all the chassis grounds? How about the ground(s?) on the steering column? I was curious about the diagnostic thing hanging off of the ECU box. I found that only two pins out of seven are connected. Any grounds Anywhere else? I'm killing myself with this car shopping. My chest is feeling the pressure.
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
- Has thanked: 2197 times
- Been thanked: 1851 times
Have you got a wiring diagram for your car? I know some of the newer ones for P1/P2 have a one pager with positions of all grounds if I recall correctly.
Unfortunately on a Russian website:
chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://volvo850.ru/shem/1995.pdf
or there is this one which is not as easy to read:
chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://www.volvoclub.org.uk/tech/servi ... agrams.pdf
Hope they are of help.
- CIK7
I'm far from smart when understanding wiring diagrams, but I will try to read the one that provided on the Russian site. Hopefully I did not just download a virus onto my phone. Otherwise, they might infiltrate my Volvo account and turn the Volvo site into a vulva site. I've never made a joke like that before. And I probably won't ever again.scot850 wrote: 09 Apr 2026, 17:35 Have you got a wiring diagram for your car? I know some of the newer ones for P1/P2 have a one pager with positions of all grounds if I recall correctly.
- Has thanked: 987 times
- Been thanked: 1075 times
On the chewed wires, was only insulation removed or were some wire strands cut?
If only insulation removed, wrap with good electrical tape to prevent shorts.
If wires were cut, use a good crimp splice after cutting the wire ends back to full wire size. If unsure how to crimp splice, reply back.
