engine will turn over fine but not start occasionally when the engine is warm. new plugs, gas filter. has been doing this for over a year. does not do this during the winter in the colder northeast climate.
when this occurs the vehicle will always start after several attempts. I have tried securing shifter into park , tried neutral, securing brake pedal, and it it starts after 3-5 tries. Worried one of these times it will not start.
any suggestions on what to look for the cause of this?
2004 xc70 occasional hard start when warm
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
Crankshaft position sensor very likely. If the plastic plate holding the wires above starter disintegrated, the CPS wires drop to the starter and suffer electromagnetic noise that starter produces. Zip tie the wires away from the starter and see how it goes.
Porkchop32
- Year and Model: 2003 xc70
May be a long shot but check ground wire to fuel pump
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
Carry a fuel pressure gauge that you can quickly attach to the injector rail the next time you have a no-start. At least then you can see if the pump is delivering. If you have an assistant that can turn the key you use an old tire gauge to check for pressure.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
read the codes for direction.raquette wrote: 15 Apr 2026, 08:15 engine will turn over fine but not start occasionally when the engine is warm. new plugs, gas filter. has been doing this for over a year. does not do this during the winter in the colder northeast climate.
- jonesg
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
I'm thinking a vacuum leak. Check gas pressure in the morning after leaving a gauge on it overnight.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- 25 Replies
- 4216 Views
Last post by 800artfreed
- 3520 Views
Last post by 93ForMe
- 38 Replies
- 6799 Views
Last post by jamadams11
- 15 Replies
- 9906 Views
Last post by FREE-PPV
- 839 Views
Last post by misha
