As I understand this fault can have several causes. Vaccuum hoses could be leaking, MAF / 02 sensors not working properly, LPG / fuel injectors not working propely, fuel pressure / sensor etc etc. I allready tried to check if there are vacuum leaks with brake cleaner on all vacuum hoses and fuel / LPG lines but has absolutely no effect on engine RPM.
I guess it would be best to check live parameters to see what is actually happening instead of guessing and thowing parts at it, but I'm having some difficulties reading the parameters like the 02 sensors as I would like to see if there possibly are differences when car is running on LPG / gasoline. I have added the read out of a live datastream from my Foxwell scanner, could you guys take a look and see if there is something out of the ordinary?
I’ve been searching the forum, lots of 250a faults but still not completely clear to me.
