Compression lost cylinder 2
Porkchop32
Year and Model: 2003 xc70
Post by Porkchop32 »
Hi all
I have a 2003 xc70 420,000 miles,
Coming home after work I experienced a loss of power made it home scanner says misfire cylinder 2
I moved coil packs and plugs no change then tested fuel pressure then to compression. Well 1,3,4,5 had 155 to 160. #2 almost none put some oil in and came up to 45.
Any thoughts or ideas would be most helpful
Thanks
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
Can you examine cylinder 2 with a borescope? Relativly cheap ones are available from Amazon that attach to a smart phone.
Examine the valves. You may have a burned valve.
420K miles is a good run.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Either the usual "burned exhaust valve" or "PCV banjo pin" dislodging itself...
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
What they both said!
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
You got 420k miles and only posted here 11 times. Please provide the username of the previous owner :lol:
04s60 2.4
04xc70 2.5t
