2001 V70XC Shift Cable Bushing
rolsen11
Year and Model: 00 V70, 04 S60R
Has thanked: 57 times
Been thanked: 58 times
Post by rolsen11 »
Hello folks of the P2 section!
I have a 2000 (P80) V70 with the AW55-50SN 5-speed transmission that I've just replaced the PNP switch on recently. The problem I've run into is that I accidentally broke the rod end bushing that connects the shift cable to the pivot arm that shifts the transmission. This part is not available individually and can only be acquired new with an entire shift cable assembly, if you can even still get that new. So I have to get one from a junkyard. Here's where I need some help.
The research I've done indicates that some P2 cars have the same rod end bushing but it's not clear if there are specific trims that have it. My local junkyard has a 2001 (P2) V70XC which might have that part. The problem is this yard does not allow people to go in the yard and requires me to buy the part before it's pulled, so I cannot check to see if this car has the right part before I spend the money for it.
Is there anybody here with a 2001 V70XC or a similar model (about 2003 or older) that would be gracious enough to confirm if theirs matches mine pictured below?
2000 V70 SE - Bought sight unseen in Cleveland, no longer my only car. Looks identical to my profile picture
2004 S60 R - M66 "Spaceball" manual transmission, Atacama "orange" interior, Titanium Gray metallic
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
looks like a match.
Its still available, not sure which one you need.
https://www.volvopartswebstore.com/prod ... %20bushing
rolsen11
Post by rolsen11 »
Was able to confirm that the 2001 had the same part, picked it up from the junkyard. Thanks!
Has thanked: 1613 times
Been thanked: 4075 times
Here’s a picture ftom my 1999, for posterior (ity)
I think it’s the same on p80 auto transmissions
Also, a dog foot
