Fuel-injector additive - Risks? '07 V70 140K
OliPhant
Year and Model: 2007 V70 2.5
Has thanked: 3 times
Been thanked: 11 times
Post by OliPhant »
Hello,
A cylinder was misfiring. Replaced one failing injector plus coils & plugs. Once warmed up car runs, idles great.
However, cold-starts are wobbly - for the first time ever. Like mini-misfires - just a few seconds then the idle steadies.
Thought maybe some of the remaining injectors might have a touch of what killed the other one. And maybe a fuel-injector additive might be worth a try. Concerned about risks. Welcome any thoughts.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2854 times
Been thanked: 1332 times
Post by matthew1 »
I've used it since 2008 on my Volvos and since 2017 on my VW... no problems. (Seafoam)
Also -> Amazon link
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
- Check/replace fuel filter if appropriate.
- New Bosch injector is only $40...you can always install the other 4 injectors. On the long run, you save money bc of gasoline cost.
OliPhant
Post by OliPhant »
Ty CN 90. Compared to OEM Bosch injectors are inexoensive. If you have used Bosch, how have they worked out?
Vova585
Year and Model: 01v70xc,2016xc70...
Has thanked: 228 times
Been thanked: 238 times
Post by Vova585 »
Bosch is a respectful brand. For a many instances bosch will be an OEM part. Multiple videos with tests show that Bosch after market injectors are and ok replacement, but not as good as OEM part in original box. $40 per one is a great price and will be decently cheap replacement. If you are at 140k and never replaced your ignition coils- might as well replace them now. In my case, they usually lasted 80-100k and dead.
Ideally, one would remove injectors, put them on test stand and check flow ammount, pattern.. then clean them and repeat the test, compare to the data from flow charts..(for $40 dollars per injector it is not a logical step unless you have test stand and time to play with it).
In terms of additives- i like royal purple injector cleaner. They are one of the top performers.
