Mischievous violet / purple radiator wire and a ECM-6110 (engine cooling fan relay - signal missing)
- Pete -
Year and Model: 01, 04, 04, 04 V70's
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
This is on my wife’s 376,000 mile 04 XC70.
I replaced the original radiator (blue box actual Volvo part), because it got a hole, replaced the heater core for the same reason.
I noticed it running hot on a few occasions over this past winter. Now that temperatures are warmer, it seems to want to run hot more frequently. I also noticed that the cooling fan does not seem to kick on. Verified with Vida that the ECM is calling for the fan, but the fan does not kick on. Tested a known, working fan on this vehicle and again, the fan did not kick on. Tested the fan out of the vehicle this thread is about on another vehicle and the fan did work.
What I am asking is this; is it most common that the purple wire is broken at some point between the fan connector and the ECM? Also, if it is typically a wire problem, where is the most common junction where this failure occurs? Or is it most commonly a fault within the ECM itself?
Thanks for your time everyone, can’t tell you all how much I love and appreciate this place.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
yes, a signal tracer or fox and hound, can trace signal along its length to the break. $25 amazon.
https://www.amazon.com/VDIAGTOOL-V210-A ... 209&sr=8-7
- Pete -
Post by - Pete - »
jonesg wrote: 21 May 2026, 22:49 yes, a signal tracer or fox and hound, can trace signal along its length to the break. $25 amazon.
Yeah…you pretty much rock Gerard. Can’t thank you enough. That will surely streamline my efforts immensely. Thank you so much!
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
Did you check the relay and fuse?
- Pete -
Post by - Pete - »
vtl wrote: 22 May 2026, 04:54 Did you check the relay and fuse?
I looked for one that coincided with what was talked about out online and listed on the fuse panel lid but ultimately I found out that “the relay is built into the power module on the backside of the fan…” according to my research. Is that incorrect?
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
vtl
Post by vtl »
- Pete - wrote: 22 May 2026, 06:54
You have to remove the upper panel in the fuse box, the relay will be under it. A bunch of screws and fighting with plastic catches.
jonesg
Post by jonesg »
Early models had external relay, yours is molded into the module on the fan.
note, I snipped the violet wire near the headlight because I didn't want to back feed voltage into the ecm, disconnected battery too.
I don't like messing with the electronics on this car at all.
a coat hanger soldering clip helps hold the wires for soldering, i used heat shrink and liquid tape to seal the joint from moisture.
its an awkward position, you can only get one hand in there.
jonesg
Post by jonesg »
The relay in the power distribution box is for the 12v feed, if you detect 12v at the fan plug its good, ..... I think.
Vs the signal switched relay in the onboard fan module.
- Pete -
Post by - Pete - »
vtl wrote: 22 May 2026, 07:16
Yeah I did see that FFM8 listing but in all the years I’ve been wrenching on Volvos never once realized there was a 2nd level to that fuse block! I’ll have to check on that. My fan is the style that has the power module molded into the rear by the way.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
vtl
Post by vtl »
- Pete - wrote: 22 May 2026, 07:45 Yeah I did see that FFM8 listing but in all the years I’ve been wrenching on Volvos never once realized there was a 2nd level to that fuse block! I’ll have to check on that. My fan is the style that has the power module molded into the rear by the way.
The "forever" fan, with brushless motor. Either that 60A relay is cooked, or ECM.
