1999 S70 AWD (FWD only) Sudden Rough running. [bad coil/plug and Dead original ETM at 100k/28 years] Topic is solved
What system would you look for given the symptoms below?
Poll ended at 11 Jun 2026, 09:54
Ignition coils - Spark Plug - Wiring - grounds (Coil on Plug Ignition Car)
5
19%
MAF cleaning - or just disconnect it, of course.
3
11%
Electronic Throttle Body codes in VIDA/Scanner
4
15%
Turbo Induction Hose path - Snorkel - Hard Pipes - Soft Pipes
3
11%
EVAP - PCV vacuum hoses - check valves - vacuum ejector
7
26%
Fuel injectors
1
4%
Fuel pressure and pump
1
4%
Compression check
0
No votes
Heated third seat relay
2
7%
Idle Air control valve
1
4%
Total votes: 27
Has thanked: 1613 times
Been thanked: 4078 times
Coming back from Vet with Juno - thought it felt a bit sluggish
Country road, 35 mph
At light, rough idle with hunting between 500-1000 rpm
Power off line is weak, but builds better above 15-20 mph
Driveable but rough 20-40 mph
On braking, no power boost is apparent, brakes work fine
Where would you look first? You can choose up to 4 options.
Winner gets 5 liters of recycled oil from Calgary, shipping and duties paid for my winner.
Have fun!!
Has thanked: 2215 times
Been thanked: 1853 times
I currently have 15 liters of used oil - Bonus Time! :lol: :lol:
Ripped off a real quick compression test
Warm 170-165-165-160-170, number 1 -> 5
No ets light..I do know this throttle body is on its last 10k of life as it surges between 2000-2200 rpm
I have had a p0455 for a while
Well , the Creator is humbling my arrogance on this one. I had a first quick look at this when I got home , and posted up the poll, because I got a glimpse of this…
Did a quick repair with some stiff fuel line, and still have rough running.
Cylinders 3 4 5 dont seem to be firing
Compression test - ok
Fuel pressure - ok
Pulled injector rails and all injectors are firing equally
Checked grounds on top of cylinder head cover - ok
Checked ground straps from cover to frame - ok, both of them
Gettting potential throttle body code and also a P0354 coil D (4?) primary failure?
Gas in the tank (added 2 gallons to right side as I was on 2-3 gallon mark in an AWD
Current thinking is ETM has pooped the bed, finally.
Split in evap hose under Intake manifold 2
Nasty Evap line and check valve
Karla spat out some muffler damping material in protest
Injectors all getting gas
Fuel pressure grossly patent
So was the ruptured pipe the fix, or is it the ETM? I'm assuming you have a spare with all the cars you have had and parted. If not, let me know as I have a few LPT ETM's unless you plan the Ebay route.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
I think she just said "hold my weave" :D
Coil D is cylinder 4 though, might have multiple issues going on but that's usually gonna be the coil itself. ETM is a possibility though, especially if it's getting throttle codes now. I know those can throw misfires when they fail.
I swapped in some used coils but still no 3-4-5 cylinder ignition
It’s front firing , too.
I will check timing in morning but I’m leaning to a bad ETM
In the meantime I am suffering daily driving the T5 m56…..
Zoom zoom zoom….
Now that is strange. Why would you have only 2 cylinders, 1 and 2 firing? Similarly, 3 not firing?
This makes no real sense how it is possible to have this condition. 1 cylinder or all but not this!
Hm. I need to think about this assuming you don't have a timing issue or 3 burnt valves.................
Fuel pressure good.
Coils known to be good, but no power on 3 4 5
Compression good.
12V supply to all coils good.
Grounds cleaned and good.
....and on KPII - there is no self test on the ETM - its quiet.
>>> ETM has finally died. Its a VOlvo MM original. 98W32 build date
Pullled the fan and radiator housing to access the ETM connector
My UBG Xmodex from Kat plugged in and self tested to perfection
You have to reconnect wiring harness to self test
I’ll document the removal in another thread
