Hi there,
Only hot air is coming out on the driver's side, no matter what temperature I set.
Everything works fine on the passenger side.
Is the ECC unit possibly defective? Does that even happen with the C/V70?
P80 C70 Hvac Drivers side only hot air, damper motor position, map of position counter, internal pictures
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
I have the same exact issue. In my case a piece of plastic fell out of the passenger side foot-well vent. I believe that is was part of one of the blend doors in the HVAC system. So for now I have the dash vents on the drivers side closed, and the ECC set to dash vents on the passenger side only. Within a few minutes things are tolerable.
The fix involves removing the dash in order to get into the vent system. A good time to reinforce the dash mounts.
1999 V70 GLT
1999 V70 GLT
- Has thanked: 2196 times
- Been thanked: 1850 times
It is possible but more likely the flaps internally are faulty or one of the servo motors is bad.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
C70 have fully obdII ecc system.
Read the codes with Vida to see what is going on.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
CoupeC70
- Year and Model: C70 Coupe '01
- Has thanked: 10 times
- Been thanked: 2 times
Dont have VIDA, will try with 850 Android App
It isn't always warm, after all. It still seems to be working—sometimes better, sometimes worse.
Could the interior temperature sensor be responsible for this? It’s just strange that the problem only exists on the driver's side.
- misha
No...850 app will not work even on 850 for ecc readout since 850 ecc still produce flash codes.
You need VIDA only for models after '98.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
It will not work on 850...if it have s,v,c,xc70 code readout...then yes...since their ECC is fully obdII compliant.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
CoupeC70
I have C70 2000
It's cold outside today.
I turned up the temperature on both sides, and warm air is coming out.
However, when I lower the temperature again, cold air only comes out on the passenger side. Nothing happens on the driver's side. Yesterday, though, cold air was coming out on the driver's side, and I even had the A/C turned on.
- 13 Replies
- 4193 Views
Last post by BEJinFbk
- 4096 Views
Last post by jvl
- 16 Replies
- 388 Views
Last post by TisMe
- 976 Views
Last post by odaikorob
- 12 Replies
- 2071 Views
Last post by cbarbsnv70
