I just replaced the brake pedal position sensor to clear ECM-9400.
Tried opening the old one that shoed 0 ohm, but wasn't able to open it up after 1/4" hobby knife inserted around the cover side. Had the new ATE sensor, just wanted to see if I can save the old one.
Anyway, after replacing the sensor, I scanned the system to make sure the code is gone. Yes. it is gone.
Now. back to the question of fual gauge on the dash. With a new pump waiting for me to drain and install & ejector/sender unit not working, I had the fuel gauge showing somewhere between 6 to 7. It went down to not working at all.
Scanning showed DIM-0004 for the fuel level sensor (signal Missing). Then, I just wanted to test and started cranking a few seconds, turn key on position 2 and repeated a couple times.
Fuel gauge came up to where it was before for a few seconds and went down to nothing.
Cranked again and stopped a couple more times. Then same thing happened.
I've tried shaking the car left & right. (driver side spring still old one). Tried again, but no change.
Any one had fuel gauge moving up & down like this?
Can ignition switch cause this? I've had 1 incidence that the ignition switch kinda locked in the middle a while ago. Since then, sometimes it stops between position 1 and 2.
Is the URO part good ?
https://www.fcpeuro.com/products/volvo- ... vo-9447804
99 V70XC fuel gauge on dash up/down and ignition switch
PatternFlyer
- Year and Model: 99 V70 XC
- Has thanked: 6 times
- Been thanked: 7 times
PatternFlyer
Yes battery is good & fully charged. It cranks good.
It is something that I never thought of.
- Grantkat
- Year and Model: 1999 s70 GLT
- Has thanked: 59 times
- Been thanked: 54 times
PatternFlyer,
Caveat - I am not particularly familiar with volvo's take on fuel pumps. However I have had many Saabs prior to my volvo and they were famous for this issue - 9-3's in particular. If these function similarly then what may be happening is the guage jumps up during initial system check but then lack of a signal from the sensor causes it to drop.
here are some things you might consider:
1) - issue with the fuel sending unit. one would be the contacts on the unit. over time they can wear out or develop dead spots.
2) - wiring - obviously corrosion BUT also check the grounds. A bad ground can potentially cause this - in the Saabs the system performs a check of the guage (hence the guage jumps up) but then there is no signal from the sensor so it drops to zero.
1999 S70 GLT ~193k
2014D VIDA/DICE
2007 Jeep Wrangler Unlimited ~ 315K
2008 Lincoln MKX ~130k
2008 Toyota Sequoia ~ 252k
Powered by coffee, stripped bolts, and questionable decisions.
2014D VIDA/DICE
- 39 Replies
- 2830 Views
Last post by VolvoOwl98
- 6431 Views
Last post by 93Regina
- 607 Views
Last post by paul850
- 913 Views
Last post by hypo
- 17 Replies
- 2704 Views
