1997 Volvo 850 broken rear wiper motor
Swedebrickinneed
- Year and Model: 1997 850 N/a Wagon
- Been thanked: 10 times
Well, that explains why the rear wiper stopped last week. Impressive failure mode, we’ll see if jb weld can save the day.
- IMG_3353.jpeg (176.08 KiB) Viewed 179 times
Learning through one broken part at a time.
gdog
- Year and Model: '96 855T, 98 S70 GLT
- Has thanked: 9 times
- Been thanked: 16 times
LOL, yeah, that's a little beyond what JB Weld can handle..
Time to find one at your local jy or ebay..
Here's one: https://www.ebay.com/itm/287195366653
1996 855T, 190K miles, N/A cams, N/A intake manifold & TB, do88 drop-in intercooler w/RIP, R ExMan, OBX_improved, green injectors, dw200, 18T w/7cm angle flange, 540i MAF housing, M4.4 VS DIY tune, wmi, Bilstein TCs, IPD sways, AEM boost and AFR gauges. Fun DD!
1998 S70 GLT, 140K miles, Bilstein TCs, IPD sways, do88 drop-in intercooler w/RIP, dw200. Want to do more mods but she says leave her car the f*** alone!?
Swedebrickinneed
Yeah jb weld is a long shot ha, found a motor for $20 on eBay last night and ordered. Always worth a shot though we’ll see if jb lasts longer than one wipe
Vova585
- Has thanked: 228 times
- Been thanked: 238 times
Given pattern of failure, it is possible that issue occurred due to "sticking" of the shaft that goes through the body of the motor case towards wiper arm. Since I never had 850, I do not know if the shaft from the motor has to go through any brass type tube that can possibly develop corrosion and as a result interfere with movement. I would suggest to bench test your replacement unit prior to instalation. Ideally disassemble and clean/lubricate moving parts.
- Has thanked: 2199 times
The answer is yes, the shaft does corrode and stick, just like the fronts can do too.
