1998 v70 gas gauge reading about 3 gallons under?
JoebobNLacey
Year and Model: 1998 V70 T5 manual
Been thanked: 3 times
Post by JoebobNLacey »
New problem started about two months ago: gas gauge suddenly starts reading about 3 gallons under. Last 3 tanks I've filled it and gauge will only go up to about 15 gallons. Seems to read linear all the way down, haven't drained it to the point of turning on the light.
Did not do any work on the car when the problem started. What could have caused this?
1998 V70 T5 manual White (Her daily driver)
1998 V70 T5 manual Black (His daily driver)
1998 V70 T5 manual Blue (rolling chassis, project)
1998 S70 T5 manual Silver (backup car)
1998 S70 T5 auto Silver (backup car)
1998 S70 GLT auto, front end totaled, now parts car
1997 960 sedan auto White
(too much more to list)
gdog
Year and Model: '96 855T, 98 S70 GLT
Has thanked: 9 times
Been thanked: 16 times
Post by gdog »
Usually that issue is caused by a bad fuel tank sending unit in the tank. Kind of a PITA to get at but not terribly tough. Found this utube that may be helpful:
Haven't looked at the schematic but typically the sending unit is just a variable rheostat (effectively a variable resistor) so once you get access to the two sending unit wires, try unplugging them; gauge should go to full, or empty. Then short the wires and then it should go to the opposite reading.
If it's still reading low during above test, could be something with the gauge itself.
1996 855T, 190K miles, N/A cams, N/A intake manifold & TB, do88 drop-in intercooler w/RIP, R ExMan, OBX_improved, green injectors, dw200, 18T w/7cm angle flange, 540i MAF housing, M4.4 VS DIY tune, wmi, Bilstein TCs, IPD sways, AEM boost and AFR gauges. Fun DD!
1998 S70 GLT, 140K miles, Bilstein TCs, IPD sways, do88 drop-in intercooler w/RIP, dw200. Want to do more mods but she says leave her car the f*** alone!?
Has thanked: 2196 times
Been thanked: 1850 times
If you typically refill the tank and don't run it full to empty, then over the years the gauge has a contact area that wears more in the range where you run your tank levels. I don't recommend running tanks lower than 1/4 tank, especially in the summer as the fuel helps cool the pump which helps more when they get older. If you have not replaced it, in fairness the youngest P80 is 22 years old (C70) or 26 years old (the rest of P80's).
