Timing belt changed, off one tooth, corrected, still get DSC
FarmallM51
Year and Model: 2001 S60
Been thanked: 5 times
Post by FarmallM51 »
2006 XC70. I changed the timing belt, started engine & while on test ride, Check Engine light came on. My handheld scanner didn't show any ECM codes, but when I got home and connected to VIDA, I got these codes: ECM-670C Camshaft position, inlet-High and ECM-671C Camshaft position, exhaust-High. I moved each cam sprocket back (ccw) one tooth, rotated the engine twice and double-checked crank & cam positions. All looked ok, but when I start the engine I get the same codes. What do I need to do to clear these codes? Thanks.
Marlin
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
vida will clear them, I thinl you have to be in delivery mode, then 'clear codes' becomes active at the bottom of the screen.
FarmallM51
You are correct. Switching to the Delivery tab enabled clearing the DTC’s. They did not return during test drive. Success!! Thanks for the help
Marlin
Noie
Year and Model: 2001 V70 T5
Post by Noie »
I just checked my VIDA today after getting the t-belt changed on my 2001 V70 T5 around new years. The ECM-644A code was still there, and it was around prior to t-belt replacement, solenoid, and hub replacement. Cleared it off and has not returned after some spirited driving. Supposedly was disabling my variable timing, but have noticed no performance improvement.
jonesg
Post by jonesg »
Noie wrote: 06 Jul 2026, 20:53 I just checked my VIDA today after getting the t-belt changed on my 2001 V70 T5 around new years. The ECM-644A code was still there, and it was around prior to t-belt replacement, solenoid, and hub replacement. Cleared it off and has not returned after some spirited driving. Supposedly was disabling my variable timing, but have noticed no performance improvement.
You have to tell vida the hard fault was corrected.
Some go away, some need a re-set.
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
VVT is for switching from Otto cycle to partial Atkinson/Miller cycle, i.e. for saving fuel, not giving more power.
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
In my recent experience, setting the exhaust timing incorrectly will set a code ECM-644A that disables the exhaust VVT function AND will decrease performance AND fuel mileage. After correcting the timing, power and MPG improved.
I actually drove it this way a few weeks before I made the timing correction.
vtl
Post by vtl »
volvolugnut wrote: 07 Jul 2026, 17:39 In my recent experience, setting the exhaust timing incorrectly will set a code ECM-644A that disables the exhaust VVT function AND will decrease performance AND fuel mileage. After correcting the timing, power and MPG improved.
I must have said "a functioning VVT" ;) Ignition angles off are of course loss of power.
Noie
Post by Noie »
jonesg wrote: 07 Jul 2026, 04:27
Thanks for the info. I reset it yesterday so hopefully the code doesn't come back. Between the t-belt and the exhaust solenoid replacement I'm not sure what else it would be if it does.
jonesg
Post by jonesg »
vida gives a few possible causes, or you can google it and see the same information.
