As in by year and/or trim level.
My right rear produces no sound. Hooked up a cheap meter to the wires and there is changing voltage
are all s70 parcel shelf speakers the same?
- rudsaki
- Year and Model: 1998 S70 T5
- Has thanked: 29 times
- Been thanked: 16 times
Previous Volvos
1969 142s Blue manual.
1966 122s Yellow with the 69 motor in it
1971 144s Red . Also the '69's motor
1973 P1800ES Aqua Manual with OD.
1971 142E Light Blue manual with OD.
1979 244DL Brown manual. Marriage/baby car. Divorce, Ex got it and sold it to my father!
1968 1800s White manual/OD. Strong runner. Killed by a '66 T-Bird
1984 242 Turbo Intercooler Silver Manual/OD
1966 1800s White Manual/OD
1985 740 Turbo Intercooler Silver Manual/OD Sold to Nephew
- Has thanked: 2199 times
If you believe the Volvo parts websites, The P2 sedans (S60/S80) also use the same rear parcel speaker. My doubts on this info is that they also list the speaker as fitting a V70 and V70 XC P80?? I had one and these were not fitted to it!!
Otherwise, it looks like they sold 'kits' which I think basically included the mounting hardware (some bolts or rivets). One version of the 'kit' is just supersedes the other one. The #12 is just the speaker, but in all cases they are NLA:
https://www.volvocarstorontoparts.ca/a/ ... 73541.html
Looking at the S60 page for loudspeakers basically agrees this is nonsense unfortunately. However, the early S80 does list this speaker as an option. It is a 40W speaker. It also lists a bunch of others, so maybe the 100W versions may fit?
- rudsaki
Thank you for that. Including S60's makes it easier to find a junkyard (newer) one. I found a 1998 Brochure and even base S70 and S80 had 8 speakers so trim level is not an issue. Lucky enough to have 2 S70s in a local Pick-n-Pull. There is also a 2004 S60 which just happens to be a T5 manual!
Previous Volvos
- 801 Views
- 11 Replies
- 2731 Views
- 1265 Views
Last post by RickHaleParker
- 13 Replies
- 903 Views
Last post by Krons
- 426 Views
Last post by EstVolvo
