question on spare key hack
Grantkat
Year and Model: 1999 s70 GLT
Has thanked: 59 times
Been thanked: 54 times
Post by Grantkat »
Another task I am combining with my dash repair will be the key hack. I have a spare immobilizer ring. I plan to connect it to the harness with my programmed key and tuck it under the dash and then use unprogrammed keys.
I have seen a couple threads that say you must remove the chip from the unprogrammed keys or they will interfere with it? is that correct?
1999 S70 GLT ~193k
2014D VIDA/DICE
2007 Jeep Wrangler Unlimited ~ 315K
2008 Lincoln MKX ~130k
2008 Toyota Sequoia ~ 252k
Powered by coffee, stripped bolts, and questionable decisions.
Has thanked: 2196 times
Been thanked: 1850 times
Nope. I have a remove starter fitted and the key is hidden under the dash to allow the car to start. It has been in the car for 14 years and no issues. I have not tried to see if it would work with a non-chipped key. Our 2 keys we use for the car are both OE chipped programmed keys.
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
My 05 XC90 had the chip in the fob die. I was determined not to pay $150+ for a key. My chipped spare is under the dash and a local locksmith cut these…no interference issues.
08 C702.5T (sold)
The non-Swedes:
Grantkat
Post by Grantkat »
just to be clear...after securing the key to the immobilizer, I can use keys that have the chip in them but not programmed... correct?
1999 S70 GLT ~193k
2014D VIDA/DICE
Krons
Post by Krons »
Grantkat wrote: 10 Jul 2026, 16:57 just to be clear...after securing the key to the immobilizer, I can use keys that have the chip in them but not programmed... correct?
Correct. My eBay ones supposedly had a chip in them…not sure/didn’t care as they only need to turn the tumblers in the steering column. Also I pushed the real chipped key/transponder pretty far forward so doubt another key would get a signal to it anyway.
08 C702.5T (sold)
The non-Swedes:
Grantkat
Post by Grantkat »
ok Thats awesome thanks!!
1999 S70 GLT ~193k
2014D VIDA/DICE
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
So I have read about this issue before, but am completely ignorant on the particulars. Is there a general write up on what exactly is needed, and how to do it ? My '99 only has one key, and of course I'd like to have a spare.
What is the immobilizer, and where is it located ?
Is it a part I can get from the junkyard ?
Does it get spliced into the wiring ?
Is this a 850 issue as well ?
As I said, I'm completely and totally clueless on this.
1999 V70 GLT
Has thanked: 1609 times
Been thanked: 4063 times
It is a trip to the dealer or someone with VIDA and an subscription to Volvo services for a North American 1999 model
Sveedy
Post by Sveedy »
^ ? Grantkat's is a '99...
Now I'm even more confused.
1999 V70 GLT
Ah, if you want to go that route, you can skip the dealer. They will cut an unprogrammed key for you for about $50, then you put your one programmed key into the spare antenna ring, and use the unchipped key to start/run
You eventually will get a code for “ key in too long” but that’s non fatal
