Coolant leak at turbo 2003 XC70
Sugawgn
- Year and Model: 2003 XC70
- Has thanked: 1 time
Hi everyone, Im new to the site but my father "Sveedy" has been on here for quite some time. I recently purchased a 2003 XC70 and named her "Suga". The seller mentioned an occasional coolant leak but didnt know where it was coming from. When I pulled "Suga" onto the ramps to do an oil change, I located the leak at the turbo. Only problem is we cant find a way to get to the gasket with it being AWD. Has anyone else encountered this problem? TIA
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
it uses copper washers on the banjo fittings, try snugging them up first.
FCP sells new washer for $1.60
some connections can be done from the top, some from below.
I removed and replaced the turbo with AWD box in place.
Shop time is 6 hours if you pull the awd angle gear.
Drain coolant, you'll still get a small shower , just be ready to dodge.
Oh yeah, those turbo banjo coolant bolts are fun.
You might need a low profile socket or skinny socket to get around stuff.
How bad are the exhaust nuts? You can take the turbo off, install lines , and reinstall with hard lines on car. Definitely replace the oil drain gasket if you do this, too.
Say hello to Sveedy from us. He’s a legend here..
Sugawgn
abscate wrote: 19 Jul 2026, 02:44 Oh yeah, those turbo banjo coolant bolts are fun.
Thank you so much for the information, ill grab one of the low profile ratchets and see if it can be done without removing the turbo.
Sugawgn
Thank you Jonesg! Ill probably order some of the washers to have on hand in case it wont snug up. I really appreciate everyones helpjonesg wrote: 16 Jul 2026, 15:00 it uses copper washers on the banjo fittings, try snugging them up first.
- jonesg
You can definitely install or snug down the copper washers without pulling the turbo, 2 copper washers per banjo bolt.Sugawgn wrote: 19 Jul 2026, 10:53
I dropped the banjo bolt, $9, found it last week , 8 yrs later, when i swapped the steering rack.
Here’s a trick on the banjo bolts. Assemble them and trap the copper washer with a o ring.
Red o are copper washers
See black ring at bottom
Get it started, then pull the oring off with a pick..
- 1422 Views
Last post by GBS
- 12 Replies
- 7118 Views
Last post by RickHaleParker
- 16 Replies
- 4466 Views
Last post by granite
- 16 Replies
- 5376 Views
Last post by lcc014
- 1628 Views
Last post by DanSC
