Ino another boost post but im still unsure.
Issue - boost / vacuum pressure is different every time I get in my car, sometimes it's perfect and will sit un vacuum '10 o'clock position' and will boost all the way up to the '2 o'clock postion' and then the next day it will hardly be in vacuum and then hardly boost.
What I've done - changed all hoses connected to the TCV and also changed the turbo bypass valve. Both of these changed seem to have give me slightly more boost / vacuum but it is still even inconsistent/ different every time I get into my car.
I was thinking this is a TCV issue? If so should I get an OEM or is there a company which sell an aftermarket one which is perfectly fine.
Thanks,
Duncan
Boost / vacuum issue 850r 1996
- Has thanked: 2199 times
Definitely sounds like a TCV or hose fitment leak. I would tend to the TCV being the issue as it is inconsistant.
Absolutely worth checking.
This means removing each one, and inspecting for splits and cracks.
Looking at them on the car is useless.
A smoke test is the best you can do on the car. Protect the MAF from smoke
- 24 Replies
- 4488 Views
Last post by bmdubya1198
- 865 Views
Last post by Sommerfeldt
- 1263 Views
Last post by chrism
- 2659 Views
Last post by gmtgmt
- 509 Views
Last post by rspi
