Hi,
Could someone with VIDA please check the OEM part number for the center bolt of the VVT camshaft gear?
Car: 2001 Volvo V40 1.8 B4184S2
VIN: YV1VW14K31F656305
I already know the VVT gear is OE 6900015 / 9454787, but I need the center bolt part number because VIDA says it should be replaced.
If possible, could you also tell me the tightening torque and angle for the bolt?
Thank you!
Need OEM VVT camshaft gear center bolt part number – 2001 Volvo V40 1.8 B4184S2
- Has thanked: 987 times
- Been thanked: 1075 times
When I recently worked on V70 T5 cam gear seals, I do not recall any instructions on MVS to replace the center bolt. I do not see that your engine would be different. Perhaps others will reply.
- 4672 Views
Last post by vtl
- 1087 Views
Last post by Filenotfound
- 309 Views
Last post by denogoh
- 2346 Views
Last post by volvolugnut
- 5162 Views
Last post by LT South Africa
