I'm having the intermittent turn signal problem where the turn signal will blink for maybe 3 or 4 times before cutting out. Happens both left and right. I read the write-up on repairing the unit by replacing the capacitor, but the info is a bit old ( gives a Radio Shack part # ).
This is what I've found. Does it look like what I need ? I'm not familiar with electronics generally, so any help is greatly appreciated.
https://www.matthewsvolvosite.com/turn- ... ights-fix/
https://www.mouser.com/en/ProductDetail ... RTag%3D%3D
Turn signal / Hazard switch issues
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
1999 V70 GLT
1999 V70 GLT
- Has thanked: 987 times
- Been thanked: 1075 times
I have had some success replacing capacitors on electronic devices. The key is to get a new capacitor of the same specifications as the old one. Does the old capacitor have a number on it like 1K F? Did the Radio Shack reference have a capacitor spec?
Small capacitors are generally cheap enough to make replacement low risk.
aeg
- Year and Model: 97 850GLT
- Has thanked: 2 times
- Been thanked: 46 times
Hell, no! I found the writeup you're talking about where he replaces the radial capacitor with an axial type. That's just all wrong. See this thread for the right way to do it:
viewtopic.php?p=294213
But note that there are at least two variants of this module, with different capacitor values. The '98 V70GLT writeup claims 2.2uF/50V, 3.3uF/50V and 4.7uF/50V in that car. The '97 850GLT writeup says 1pcs 3.3uF/50V, 2pcs 10uF/50V, and 1pcs 33uF/63V in that car. It's not a mistake in the writeups, you can see in the pictures that the two boards are actually different. You might want to buy the full capacitor assortment, or else pop your module open before ordering to see which one you have.
Contrary to the second writeup, I would suspend the board in a small vise while working on it. I would flow a little fresh solder into the joints before trying to remove the old caps. And I would use a solder sucker instead of wick.
- Sveedy
^ Thanks aeg ! I'd guess I have the '98 style as the car is a early '99. But I think I'll open the unit up and see what I can see first.
Of course mine doesn't look like either of those. Mine isn't the toggle type of switch.
1999 V70 GLT
1999 V70 GLT
If you do not have a small pencil tip soldering iron, I suggest you get one. The big loop soldering irons may put too much heat into the board.
I have bought parts from Mouser.com with good experiences.
- Been thanked: 4064 times
Stick a junkyArd request in with robert for a hazard switch. I don’t think they fail often.
rrres
- Year and Model: 1999 v70XC
- Has thanked: 12 times
- Been thanked: 34 times
I've had this happen last week on my '99. Had the AC on high and turn signal would blink about 3-4 times before cutting out. If I turn off the AC, blinkers would start working properly again. I recharged the battery and problem solved.
It's blowby
- Has thanked: 2197 times
- Been thanked: 1851 times
Does that mean you have a charging issue or too many short trips not recharging the battery enough?
- Sveedy
rrres wrote: 28 Jul 2026, 09:36 I've had this happen last week on my '99. Had the AC on high and turn signal would blink about 3-4 times before cutting out. If I turn off the AC, blinkers would start working properly again. I recharged the battery and problem solved.
I checked this possibility out, and unfortunately not the problem.
My plan as of now is to wait till I can find a good used unit before taking mine out and apart. Intermittent is better than nothing at all.
1999 V70 GLT
1999 V70 GLT
I found my hazard switch from Shagg 1999 v70, last tested after I removed a Tesla from circulation. Do you need?
- 4445 Views
Last post by aewoodhouse
- 848 Views
Last post by jalbs
- 976 Views
Last post by Metallo
- 1360 Views
Last post by ggleavitt
- 1615 Views
Last post by boostedxc
