We've got a bunch, but this is a different take, and beautiful. Wastegate, FPR, EGR, boost gauge, purge valve, TCV with Red/Yellow/Blue, and more. This is mid-1990s 850 Turbo 2.3 liter.
Sent in by anonymous user Dee Eff.
5-cylinder HPT vacuum diagram B5234T
- Has thanked: 2865 times
- Been thanked: 1332 times
- BlackBart
- Has thanked: 967 times
- Been thanked: 923 times
That's good. Now is that a Euro 2.3, or is that the same engine as the '94 T-5? From the diagram, that looks identical to my system. I guess there would be no reason to change all that for variations - it would be changes in pistons, valve timing, boost control, etc.
EDIT: It says right on there, 1995.
- BlackBart
Interesting in that I've always had a code for "EGR flow too low." I've removed it, tested it, cleaned it, and now they're no longer available new. Always ran great, plenty of power, no issues, just this code. I've replaced all the colored vac lines with silicone.
BUT...I don't think I've ever messed with the EGR vacuum regulator, which is the bit on the upper radiator shroud I think. Hmm.
- Olegs855R
- Year and Model: 1995 855 Turbo “R”
- Has thanked: 6 times
- Been thanked: 23 times
Yes, upper radiator shroud. Has 2 ports marked white and yellow.
I drew this a while back as I have a rotten memory and I’d need to try to decipher the hood sticker. It hangs prominently on the wall . It’s around 2 feet square.
- Has thanked: 1613 times
- Been thanked: 4075 times
If you have an early 1999 like mine, it’s likely the vacuum diagram is wrong, Volvo used up their supply of 1998 stickers on our cars. I think I documented this in Elizabeth msintenamce thread
- 3987 Views
Last post by Colomonza
- 2695 Views
Last post by legalstuff
- 3388 Views
Last post by Hoytster
- 11 Replies
- 5713 Views
Last post by Sommerfeldt
- 819 Views
Last post by jimmy57
