Pre-install exhaust man. and turbo 2004 XC70
- P2metoo
- Year and Model: 2004 XC70 205+
- Has thanked: 22 times
Hi All. Getting ready to reassemble my engine with a new head gasket in a week or so. Does it work OK to pre-install the exhaust manifold and turbo when lifting on the head? I have another person to help lift it on. Thanks.
2004 XC70 205+
2007 Honda Pilot 200+
1971 F250 Camper Special 170+
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
It would not make you life easier. Better bolt the exhaust on after the head is installed. I screwed the new exhaust studs in and routed them into the manifold while installing the head this way:
Btw, protect the head with cardboard from your gasket kit while you positioning the head, to avoid scratching it.
When done, tilt the head slightly backwards and pull the cardboard. Easy-peasy, no scratches.
- P2metoo
Thank you. This is a great idea. I will see what I can do to copy this.vtl wrote: 15 Aug 2026, 17:12 It would not make you life easier. Better bolt the exhaust on after the head is installed. I screwed the new exhaust studs in and routed them into the manifold while installing the head this way:
2004 XC70 205+
- 1773 Views
Last post by Oro
- 1452 Views
Last post by carboncow
- 3156 Views
Last post by jimmydean012
- 2194 Views
Last post by EngineeringBloke
- 526 Views
Last post by Flyingdutchman
