Why do I have to pull my front door handle twice to unlock from the inside? I thought that was a feature only for rear passengers.
2013 xc60
Must pull door handle twice to unlock.
850TurboTurtle
- Year and Model: 96 850T, 05 S80T6
- Has thanked: 12 times
- Been thanked: 5 times
- RickHaleParker
- Been thanked: 977 times
It is programed that way.850TurboTurtle wrote: 26 Aug 2026, 12:52 Why do I have to pull my front door handle twice to unlock from the inside?.
You can have it both ways.I thought that was a feature only for rear passengers.
How to Turn It Off (Single-Pull Exit)
If you prefer a standard "one pull" exit, you can change this behavior by adjusting your central locking settings so the car unlocks automatically when you put it in Park or turn it off.
On a 2013 model equipped with the Sensus infotainment system, you can adjust this through the center screen console:
1. Press the MY CAR button on your center dashboard stack.
2. Select Settings on the screen.
3. Scroll down and click on Car settings.
4. Go to Locking.
5. Look for Auto Door Unlock or Remote and Interior Unlock.
6. Switch the configuration to All Doors.
Active
Past
Past
850TurboTurtle
Thanks for the reply!RickHaleParker wrote: 26 Aug 2026, 13:22On a 2013 model equipped with the Sensus infotainment system, you can adjust this through the center screen console:
4. Go to Locking.
I tried this method and nothing changed. Are there different instructions for different years?
- RickHaleParker
What is this one?850TurboTurtle wrote: 29 Aug 2026, 18:57 I tried this method and nothing changed. Are there different instructions for different years?
Still not unlocking automatically when you put it in Park or turn it off the car. ?
After car auto unlocks, then you need only one pull to open door.
Active
Past
Past
