Volvo P2 key cloning vs programming
darylrobert
Year and Model: V70 240 740t xc70
Has thanked: 6 times
Been thanked: 44 times
Post by darylrobert »
**Just to clear up. YES volvo keys can be cloned, if the locksmith knows how, theres a volvo trick
The aftermarket Silca key and the Aliexpress key are both plastic and noticibly lighter to the genuine volvo key. The Genuine volvo key can only be added via programming to the car, that is, it cannot be cloned (hence taking it apart). Programming can be expensive as in my case the dealership was unable to "add key" after downloading the software and follow up said they needed another 3 or more hours to "CEM update".
Cloning is easy when a locksmith knows how, thats the problem. The battery needs to be dis connected after every successful immobiliser log.
volvo p2 keys
volvo p2 keys
ID48 chip
ID48 chip
volvo read only ID48 chip.jpg (57.17 KiB) Viewed 740 times
genuine volvo key marked wrong
chip marked wrong.jpg (52.23 KiB) Viewed 740 times
ID48 cloning.mp4
(4.52 MiB) Downloaded 257 times
cloning aftermarket and genuine key
Has thanked: 2196 times
Been thanked: 1850 times
So to clarify my understanding, the 2 aftermarket versions do not need the modification to the transponder key chip, it is only the OE Volvo that needs to be modified for this to work?
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
scot850 wrote: 30 Aug 2026, 11:45 So to clarify my understanding, the 2 aftermarket versions do not need the modification to the transponder key chip, it is only the OE Volvo that needs to be modified for this to work?
If I get it correctly. The OEM chip needs replaced because it is read only. You cannot program a new ID code into it.
Under what conditions you need to reprogram the OEM key not the control modules is unclear .
Active
Past
Appreciate helping me understand this and the options guys!
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
RickHaleParker wrote: 30 Aug 2026, 16:14
ID48 chip was like two bucks for a dozen last time I looked. Exacerbating, of course, but replacing the chip is still two orders of magnitude cheaper than cutting a new key and mating it with car via dealer.
RickHaleParker
vtl wrote: 31 Aug 2026, 21:44 Exacerbating, of course, but replacing the chip is still two orders of magnitude cheaper than cutting a new key and mating it with car via dealer.
True but still missing something. Do the OEM chips ever go bad?
Active
Past
vtl
Post by vtl »
RickHaleParker wrote: 31 Aug 2026, 22:32 True but still missing something. Do the OEM chips ever go bad?
Of course.
RickHaleParker
vtl wrote: 01 Sep 2026, 04:37 Of course.
Oh yea ... ElectroMagnetic Pulse wiping them clean. :wink:
Active
Past
Has thanked: 1609 times
Been thanked: 4063 times
My new key addition at dealer was $80 in NYC for software and time
