suggestions: best heater fan for the money?
- Has thanked: 311 times
- Been thanked: 817 times
If the issue is noise, try a drop of oil on the shaft and forget about it for a year (or more)! For the money, it's unbeatable.
Otherwise I can't help, no recent experience with that part.
Nissens and TYC seem to be decent replacements on the later p80s
- Has thanked: 2199 times
I think you have to be careful as I think there is are 2 different ones on earlier cars or cars with MCC v's ECC controllers. If you have no luck, I have units I have tested on the shelf. You didn't say (unless I missed it) which year this was for.
Good Luck!
Good Luck!
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
Hi all,
Thanks for the info. My two 96 850s should be updated. One's a base na that has the more-or-less manual controls and the smaller resistor pack, the other is a turbo. I didn't realize there's a difference in the fans.
I believe the turbo dash hvac control module on the turbo car isn't working, but I'm not sure because the resistor pack seems to have failed, but I can't test it because there's no signal from the controls to move vanes around, etc.
I have a fan control that works pretty well.
I've mentioned elsewhere that I'm sure the 30 amp circuit is overprotected causing the resistor pack to fry when the fan starts to drag on startup. My turbo 850 fan (that doesn't work with the dash controls) does drag on startup. The takeoff lead I use to run the fan controller has an inline fuse. The fan will run with a 25 amp fuse, but blows a 20 amp. It wouldn't blow the oem 30 amp on that circuit though, because the resistor goes out first.
The same thing happened on my 93 GLT. I replaced that fan with a new one (Nissans, maybe—thanks abscate for jogging my memory)
While I had the old one out of my 93 GLT, I did a comparison test new vs the old one that took out my resistor pack. Using jumper cables straight off the battery, the new fan lets just a tiny spark when I hot wire it and runs smoothly as it should; the old one that took out my resistor pack lets a fat spark on startup, but then runs fine. But at that stage of startup drag (okay, my theory, but the evidence seems good), they don't get to run b/c the resistor pack goes down first.
In my base 96 850, the heater fan and controls (which are mainly cable operated) have been working well. So I want to upgrade that fan before I use it this winter to avoid losing another resistor pack—then still needing a new fan, too.
If I ever get the GLT electronics working again, I'll never run more than 20 amps out of the fuse box (with a new fan) on that circuit.
There must be a way to fix those resistor packs. Any tips on that?
Bottom line: I need a couple of new fans—and then on the turbo work backwards from there.
Sorry for the ramble. Past my bed time!
wheelsup
- Year and Model:
- Has thanked: 16 times
- Been thanked: 22 times
I bought a cheapie off Amazon years ago for about $40. Still runs fine.
Looked like this:
https://www.amazon.com/Garage-Pro-Blowe ... 0FDJV3XQL/
Looked like this:
Looks like a parts break between
850 1992-1997
S/V70 1998-99-00
850 1992-1997
S/V70 1998-99-00
JimBee
Thanks, wheelsup for that pointer. I'm thinking I'll try the Garage-pro source, though I've not heard of them before. They must be a clearinghouse sourcing parts from different manufacturers. Current posted price is $53+
- V50M66
- Year and Model: 1998 V70 AWD
- Has thanked: 26 times
- Been thanked: 94 times
Just get a used one from the junkyard or eBay. I'd take a good used Genuine blower over a cheap aftermarket one.
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
- 697 Views
Last post by rjS60Turbo
- 51 Replies
- 8853 Views
Last post by RussB
- 24 Replies
- 5687 Views
Last post by bronco
- 6029 Views
Last post by jimmy57
- 2720 Views
Last post by Williamad33
