Ok, just finished with heater core R&R and everything is back together. I can't get the key to move past position 1? Is there some kind of idiot lock I forgot to trip? Reminds me a little of when you need to turn the wheel a little to get the ignition to start - I think this is sometimes a towing feature?
Edit: is it possible that when the steering column was out the tumbler was damaged, eg ? viewtopic.php?t=67531
Key won't go to position II after heater core??? Topic is solved
beewstew
- Year and Model: 2004 xc70
- Has thanked: 34 times
- Been thanked: 5 times
Yes, I had the steering column all the way out per the charm instructions. I thought I followed the "Installing the steering wheel lock module
" part properly, but not the key won't turn. Related, I can't pull VIDA codes if the key won't go into position 2.
https://charm.li/Volvo/2004/XC70%20L5-2 ... ir/L.H.D./
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
I replaced three heater cores on our S80 and V70 and never removed the steering column. I’ll admit the column does present some obstruction to the core’s R and R which results in “some” damage to the fins on the lower side of the core. A thin sheet metal or plastic strip, cut to the same width of the core, can act as a sort of “shoehorn” to minimize that damage while sliding the new core in.
Maybe someone else with steering column experience will offer up some advise on that lock issue.
Before you fully insert the column is it possible to turn the key to retract the locking pin?
beewstew
Yeah, I can see now why it wouldn't be necessary to remove the steering column. Tight fit but it could have worked.
Yeah the key worked just fine before I took everything apart
- Been thanked: 4063 times
Sounds like the trans interlock isn’t back in right, pretty clearly
beewstew
Just making sure I'm thinking about the right thing. There's a semi-rigid cable that's flexible that clicks into place in the back of the key cylinder.
Key has to be in position 1 to shove that all the way into the barrel and then key should rotate to position two or three even if the power is off?
beewstew
Thanks for the suggestions. Problem seems to be resolved. There was some kind of goofiness in the lock cylinder box so I followed an old comment and used a Dremel and a screwdriver to remove the metal plate on the bottom. a spring fell out and then the key turned and then the car started. I'm calling it good as the boy needs to go to school tomorrow
- Has thanked: 987 times
- Been thanked: 1075 times
I have to wonder how many of the 20 year old Volvos have steering lock bypass now.
Mine does.
Mine does.
- 11 Replies
- 9784 Views
- 5052 Views
- 554 Views
Last post by pbob42
- 1349 Views
Last post by RickHaleParker
- 4871 Views
Last post by Oly850
