Still not sure what to take from that!
Anyway, he bought this car which he loves and it needs a lot of catch up work and a little floor welding eventually. Paint is poor but he wants to change the color eventually.
Spent about 6 hours in the garage showing him how to strip the rear brakes including the parking brakes, test the cables, and generally assess the car before reassembling.
We had a couple of hiccups on the way as it has been over 20 years since I last worked on one and my memory is not that great!
The issues we had is he wanted to replace the 2 spring clips for holding the parking brake shoes in place on the backplate. It was only when I was cleaning the last 2 bolts I discovered the bolts had thread sealing on them. D'oh! No mention of this in the Haynes manual so all the brakes had to come apart again to add the thread sealer (to prevent back axle oil potentially leaking into the brakes).
However we found a way with both us working together to strip the rear shoes out in about 2 mins!
Replaced the parking brake shoes and hardware, filed the caliper faces and fitted new pads and rotors. Also checked the caliper bleed screws would loosen. We had wire brushed and soaked them a couple of times with PB Blaster and they came loose nicely.
Finally we had to tighten the parking brake cables as they were really loose. The Haynes manual again was useless as it had the wrong pictures for this car's parking brake assembly adjuster. We figured it out and now he has a working parking brake.
We also treated the front brake bleed screws and all the flexi-hose joints. The plan is to swap them all on the next visit as well as the front calipers, rotors and pads.
Lastly a full brake flush and bleed
We assessed the further work needed (timing belt and PCV he has already dealt with). He has a reasonably sound bas to work from but a fair amount of stage 0 work still to do.
