Hi,
I bought an used Volvo 850 sedan powered antenna motor that i wanted to install in my Volvo s70 1998. It works without any issues and i installed a new mast.
But what i did not realize is that the nut on the outer grommet is different in size so it won't thread on the 850 antenna tube.
So do i have any sort of options here? I was thinking if i were to buy an outer grommet and nut from an 850 sedan that i could then thread it on but it will probably leave a gap against the fender of the car (maybe possible to use some sealant?).
Or if i were to change the tube from a s70 antenna motor to the working 850 antenna motor?
Either way anyone who has done this or in general what would be the best idea to move forward with this.
Volvo s70 fitting an 850 powered antenna
AwfulAccuracy
- Year and Model: 1998 Volvo S70
- Has thanked: 2215 times
- Been thanked: 1853 times
I didn't realize the 850 one was different in any way, although it was used on other models if I recall. Do you have all the parts to fit it. Saw this for sale while trying to find a picture of a 850 power antenna:
https://www.ebay.ca/itm/327360621739?_s ... R8KhyZCbaA
Pricey, but find another one.
Shame you are not closer as I have several P80 power antennas in my stash, all work and where needed have new antenna.
AwfulAccuracy
Hi Neil, Appreciate you replying to my question regarding this.scot850 wrote: 25 Sep 2026, 08:52 I didn't realize the 850 one was different in any way, although it was used on other models if I recall. Do you have all the parts to fit it. Saw this for sale while trying to find a picture of a 850 power antenna:
I have everything except the 850 grommet and nut. But i have a person who would be willing to sell that to me.
But the 850 and s70 back fender is a bit different so i’m not sure if it will fit good enough to have some silicion between the grommet and the body of the car.
Or if perhaps i use the s70 grommet and then modified it and use the 850 nut?
Everything else in the installation fits without any issues and works with the radio up and down.
AwfulAccuracy.
