Searching for Headlight advice
MarinerMan
Year and Model: 1999 V70 N/A
Has thanked: 6 times
Been thanked: 10 times
Post by MarinerMan »
Greetings Y'all. I have had problems with either stones or in one case, a kid with a BB gun causing chips in my headlight lenses. Does anyone have a way to fix these? it is about a 1/16" hole with a bit of spiderweb of cracks around it. I was thinking about using the UV setting resin used for windshield cracks, but I didn't know if that would work. Also, has anyone used any sort of protecting films or covers to protect them from impacts? I would be happy to hear from others what they have done. I have gone through five lenses so far and I am trying to keep them better than I have so far.
Has thanked: 2212 times
Been thanked: 1853 times
You can get new replacements, but them put a thick 3M clear film over the lenses to protect them. I'm not sure if I still have any spare lenses for a 99? P80. As you probably know swapping the glass lenses are pretty easy.
I will likely have a parcel heading to Abscate shortly with a couple of parts. If you don't mind aftermarket I can add a couple of lenses if I still have spares. Sensing one shipment to the US is easier than multiple as the system has become stupid getting stuff into the US.
Neil
MarinerMan
The one that just cracked was a jewel which is harder to find than the ones with ridges. I will get some of the 3M film you mentioned. I have spares of the regular ones, but not these. Thanks for the tip on 3M film. I will look it up.
I knew I should have bought a pair of used Jewel lenses that came up for sale a while back. They wanted too much for items that were ok but not perfect.
Good luck with the film protection.
Has thanked: 1613 times
Been thanked: 4075 times
I can get those lenses to you if Neil has spares, MarinerMan. Looks like we need you this weekend….stay dry!
jmartin919
Year and Model: S70 GLT SE 2000
Has thanked: 97 times
Been thanked: 42 times
Post by jmartin919 »
Which side are you needing?
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
