CD problem, 2001, s80
You will need to turn the key on to move the gear selector to the rearmost position. Using a flat blade screwdriver pop the larger trim panel up from around the gear selector working it up from the rear part of the panel. After popping off the panel around the gear selector rotate it to the right a 1/4 turn to gain access to the 2 screws located at the bottom side of the climate control panel. After removing the 2 screws start pulling outward on the bottom side of the climate control panel at a slight angel and grab from the sides and pull outward releasing the clips on the top side. Then remove the 2 screws on the bottom side of the radio and pull outward releasing the top clips. I hope this helps and good luck!!
- 1168 Views
Last post by SJLucky
- 11 Replies
- 2910 Views
Last post by KobeBryant
- 778 Views
Last post by rdklxprs
- 1921 Views
Last post by volvolugnut
- 745 Views
Last post by Synergychaz
