I have a 1996 850. For about a year, the airconditioning has been acting up. First it blows as cold as it ever has...then, after 30-45 minutes, it abruptly turns warm. If I turn the AV off, and back on in several minutes it will cool again. I have checked the coolant, which seems normal. Ideas about how to diagnose and remedy this will be greatly appreciated.
John
Intermintantly hot AC
- Tsquared
- Year and Model: 11 C30
- Has thanked: 1 time
Do a search on my posts about AC. I had this happen a few years back. It was a hose that was collapsing.
T
Playing in the sand again
T
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
JRL
- Year and Model: Several
- Been thanked: 16 times
Just a thought, but if the system has some clogged lines or is generally filthy, it can get too cold and without all the internal relief valves working properly, it freezes and will shut off. After you have turned it off, the ice melts, opens the lines again and cold air blows.
That's just ONE possible senario
- Tsquared
If memory serves me, it was the bottom hose. The AC system is one of the few items I let my INDY work on. Every time I try to save a little $$ on an AC repair I spend more than what I could hire it out for...
T
T
'11 C30 T5
Similar behavior with my 1996 850 2 summers ago. It was just low on refrigerant. My mechanic checked and added R134a to recharge it. It is still doing fine going into the third summer since then.
1998 S70, 5 speed manual, 146k, wife's car
1997 850 Wagon, 5 speed manual, 185k, son's car
1996 850 5 speed manual, 220k
1985 MB 300D 268k, running on B20 biodiesel
1983 MB 300D 240k , converted to vegetable oil
1981 VW Vanagon 184k
- 22 Replies
- 924 Views
Last post by TisMe
- 17 Replies
- 4339 Views
Last post by villagepc
- 48 Replies
- 11018 Views
Last post by bmdubya1198
- 1732 Views
Last post by jimmy57
- 3600 Views
