-95 850 wagon, image identification please!!
Sarasota
Post by Sarasota »
Hi,
I have a transmission fluid leak from a seal that I need help identificating please. I can not order a new seal because I dod not knwo what it is called.
If anyone knows, or even better would know where to get it, I would greatly appreciate it.
[img=http://img241.imageshack.us/img241/6574/sealxj9.th.jpg]
Sarasota
Post by Sarasota »
Please does not anyone know what that seal is called that is on the image, I am going nuts....
Help Please
HareBall
Post by HareBall »
I can't help you with this, but have you downloaded the service manual in the sticky at the top of the page? It might be of help to you.
Larry
Li'l Red Wagon
97 855 GLT
Sarasota
Post by Sarasota »
Yes I did download it but could still not find it..
Argggh, I am going nuts.
akitawagon
Year and Model: 1997 855R
Post by akitawagon »
VA_IS does not list a physical seal part for that area of the transmission and just lists "P/N 1161409-6 chemical gasket", which sounds like you need to get a tube of Volvo liquid sealant.
Someone who's already done this needs to verify this.
1998 V70 T5 223K
1997 855R 215K
1997 855R 124K KIA... distracted driver on phone
1997 855 T5 141K KIA... water pump
1996 850 GLT 160K
1995 855 GTA 325K KIA... distracted driver on phone
1993 850 GLTS 201K KIA... t-boned
Sarasota
Post by Sarasota »
Thank you for all your efforts, "akitawagon" on what page (and section) did you find this part#?
Do you or anyone else have any idea what that part is that connects to the transmission? It looks like a "cup" lid of some kind??
Has anyone sealed this area before? I assume anyone that has removed the tranny shoudl have done this or?
Thanks again for all the help
Sarasota
Post by Sarasota »
I believe it is part# 30a on this picture (you can click on it to zoom in):
"http://au.geocities.com/ozbrick850/transaxle.jpg"
Has anyone removed this part before and re-sealed it?
How would I apply the RTV Sealant?
I guess I will be getting alot ot oil coming out when I removed this cover, huh?
Sarasota
Post by Sarasota »
Sorry the image did not work, here it is again:
[img=http://img181.imageshack.us/img181/6885/transaxlekc4.th.jpg]
CarVolvo
Post by CarVolvo »
i have never removed one... and out of the 6 850's ive had they have not leaked.
you referring to 30a which is the protection casing.. part number 6843815.
why not call your volvo dealer and ask their opinion on this or a trusted independant. See what the cost of the replacement gasket it or ask what they charge to replace it to give you a heads up of whats involved.
THE FLEET!:
93 854 GLT 20v non-turbo 435,000 KM +
94 854 20v non-turbo 215,000 KM ..new engine
87 745 B230 non-turbo 250,000 KM (newest edition Jan '07)
86 244 GL B230 non-turbo 460,000+ KM
akitawagon
Sarasota wrote:Thank you for all your efforts, "akitawagon" on what page (and section) did you find this part#?
VADIS is an older version of the parts/diagnostics/repair program that Volvo techs used to use until a newer version was introduced. You can order a copy of it on ebay.
The diagram you posted is the same one provided by the program, which also gives a listing of OEM parts/part numbers. If you're referring to 30a, it's called the protecting casing like CarVolvo said. I have no idea what is behind this casing or if it the main source of your leak.
Since no one else has spoken up, you should take CarVolvo's advice and check with a good dealership or indy shop that works on 850 transmissions.
1998 V70 T5 223K
1997 855R 215K
1996 850 GLT 160K
