i have a 94 850 nonturbo. i had to repair the flame trap hose because it was cracked (this is the black plastic tube that feeds into the flame trap). to do this i had to :
-remove the fuel line rack
-all the vacuum connection at the throttle body, etc
-i removed the injectors (just to see what they look like on the working side) and put them back in
after fixing the flame trap tube, i put everything back. now it cranks but does not start. this is what i have done.
-changed spark plugs , no start
-checked the ignition wires for current using a timing gun, there is current, still no start
-removed the plugs and put a teaspoon of gas directly in it, replaced plugs, still no start
-checked the fuel supply regulator (the one on fuel rail) for vacuum leaks..it holds a vacuum,
i'm at the end of my wits....any ideas? please help
tough no start problem
2008 XC70 3.2 Fuel Pressure Specs
- Has thanked: 2861 times
- Been thanked: 1332 times
Do you have fuel at the rail (bicycle tire valve)?
Did you bump or knock the mass airflow sensor connection?
darren
ok this has happpen to me 3 times now i start my volvo it runs only for 2 seconds then dies. i crank it and it sounds like i have no compression the first time this happened i check eveything over and found no problems so i just cranked it over for about 1 min. and sounded like it was going to fire but it didnt so i cranked it again for a min and it finaly started. well it ran great for about 5month then the same thing happened so i just cranked on the starter for awhile and then it started. now 6month later i now the same problem. so the question is what could cause this? i have spark, i have fuel,
- 413 Views
Last post by Ozark Lee
- 1456 Views
Last post by dandan
- 1585 Views
- 12 Replies
- 3407 Views
Last post by Jaguar xjs
- 19 Replies
- 7465 Views
