How do you know when you have a stickin caliper?
blackstarpower
- Year and Model:
I was just curious as to what the symptoms were for a sticking caliper. I am getting ready to do my brakes and am gathering parts.
1998 V70 XC
- Has thanked: 17 times
- Been thanked: 35 times
Wheel on the side sticking will usually make a sound and vibrate your steering wheel, also pulling your car in the direction of the sticking caliper...if on the front. If on the rear, the car will pull in the opposite direction but things won't be as obvious. Intermittent sticking is harder to diagnose. Also, when you look at the pads on the side of the sticking caliper when you change your brakes, you'll notice considerably more wear and probably uneven wear. Good luck!
blackstarpower
- Year and Model:
What causes a caliper to stick and is there any maintenance trick you can do to alleviate the sticking? Also, what do you think about the repair kits and do they work? Repair kits cost about 1/4 the price of a new caliper.
1998 V70 XC
- Year and Model: Many Volvos
- Been thanked: 76 times
Normally it is caused either by rust or debris on the caliper or the caliper bracket. It can also be caused by stuck or rusted caliper bolts. If you clean and lubricate the mating surfaces with a thin layer of brake grease and also lubricate the pins they shouldn't stick.What causes a caliper to stick and is there any maintenance trick you can do to alleviate the sticking?
As far as the repair kits go, they usually do work but you really need to hone out the cylinders to make them right.
Are you sure you need to rebuild or replace your calipers? So long as the car stops and they don't leak they should be fine.
Beyond service replacement of the pads and/or rotors what other brake problems are you trying to solve?
- 15 Replies
- 6482 Views
Last post by wizechatmgr
- 24 Replies
- 5385 Views
Last post by XC70Rider
- 877 Views
Last post by FCPEURO
- 3071 Views
Last post by mrbrian200
- 2198 Views
