'99 V70 AC Problem
Rob3
Post by Rob3 »
This seems to be somewhat common, yet I haven't seen a solution.
AC works fine until outside temp approaches 90
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
The compressor has a thermal sensor that will turn it of if it decides the compressor is overheating. My understanding is that the condition is exacerbated by an improperly shimmed A/C clutch.
There was a good thread on the subject over on VS that includes a good writeup on re-shimming the compressor.
http://volvospeed.com/vs_forum/Ac-Therm ... 76833.html
Rob3
Post by Rob3 »
Thank you! That was excellent.
Does anyone know what temp the switch is supposed to open at?
My thought is to replace the "bad" one with a good one (of a completely different type) and mount it on the Compressor, somehow.
cyclmck
Post by cyclmck »
Check to see if the fan is coming on, that would explain why the a/c works when moving but not at a standstill (no airflow through the condenser means no heat exchange)
Rob3
Post by Rob3 »
The Fans all seem to be working fine. Engine temp is fairly constant, too.
The only thing that seems to matter is outside temperature. Below 85
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
Also -> Amazon link
Rob3
Post by Rob3 »
Thanks for the info.
I hope to get a look at this in a couple of weeks. I'll remember to look for this, as well as the Compressor Clutch Gap and the Thermal Cutout Switch.
Thanks again for everything, including the reply.
Rob3
TheDrivenMan
Post by TheDrivenMan »
I'm having the same issues with my '95 850
Ice cold a/c for a while, then nothing; turn off the a/c and wait a few minutes and it is cold again.
The cooler it is outside, the longer the a/c will function normally. If I'm in slow traffic on a very hot day, the a/c fails too cool at all.
Plenty of line pressure
R
Robert
The Driven Man
New Owner 1995 850 Turbo Wagon
www.TheDrivenMan.com
Rob3
Post by Rob3 »
Sorry. I haven't tried to fix this yet. I've so many other things going on and the cool lasts from home to work and back, so I haven't been trying too hard to find extra time. I know it needs to be done...
Rob3
Post by Rob3 »
Just FYI:
I removed the Relay that Operates the Compressor. I disassembled it and looked at it. The Relay showed signs of heat, but it showed a Reliable Connection with my Meter. I operated the Relay several times and each time the Connection was reliable.
I placed a 12 Volt Lamp across the Relay Coil and inserted the Relay back into the car. I routed the wires from the Lamp so that I could position the Lamp near my Wipers. In this way, I can see if the Compressor is being told to turn On while I'm driving down the road.
Since then, the AC System has not failed. It has been a couple of weeks, so far. I don't know if it has to do with the Relay, or if it is just coincidence.
If things change, I'll let you know.
BTW, the Relay is in the Triangular Box nearest the Battery, with the Large Fuses. It is the narrow Relay which is closest to the Engine.
Rob3
