The tire pressure info is not on the driver's door jam.
I've looked around for it and can't find it.
Can someone tell me where to locate it?
What would my target tire pressure be for my 96 GLT?
Thanks!
96 850 GLT Tire Pressure info?
- Year and Model: Many Volvos
- Been thanked: 76 times
I think the sticker is on the gas door. I run mine at 35 lbs.
- Tsquared
- Year and Model: 11 C30
- Has thanked: 1 time
You can also check the tire manufacturers website. Some of them will list their recommendations on tire pressure by car type. I have found that different tires will ride better at different pressure. The 35 lb is good rule of thumb but the current set of Pirrelli 400s that are on my daughters car ride better at 38 lbs. The tire is rated to 40 or 45 lbs so I am still under the maximum pressure.
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
- Has thanked: 17 times
- Been thanked: 35 times
I also run 35PSI, but depending on your road condition, type of tires and tolerance for bumpy rides, you can go more or less....more if you like a tight ride and don't mind the bumps....less if you want a softer ride and don't mind some loss of handling. 32~40 or so seems to be fine as far as wear on most tires.
JRL
- Year and Model: Several
- Been thanked: 16 times
You guys do NOT know how to read these.turbotim2 wrote:I just looked at mine and it says 36 front, 41 rear. I run mine at 35 though.
When driving alone or with one others you use THE OPTIONAL pressure which is about 32 or so.
The "standard pressure" is for a fully loaded up vehicle, READ the labels
- 1424 Views
Last post by crlande
- 15 Replies
- 33946 Views
Last post by cn90
- 2646 Views
Last post by pgill
- 1588 Views
Last post by hoboken
- 1503 Views
Last post by Salomons Driveway
