The driver's window on my 95 850 GLT is stuck in the down position. When I press the switch I hear it click (like a solenoid) but it doesn't move. Would shooting it with WD-40 (to clean) ruin it? Any help would be appreciated, if only to get it back up until I can work on replacing it.
Thanks.
850 GLT Driver's Window
CarVolvo
- Year and Model:
Im not sure if your hoping the WD will lubricate something or clean out the system.
Have you dropped any coffee or other beverages on the unit recently?
You can pop the unit out and check it to make sure its not gummed up with old sticky drinks spills.
Chances are that the drivers door window button is defective because it gets used a lot.
THE FLEET!:
93 854 GLT 20v non-turbo 435,000 KM +
94 854 20v non-turbo 215,000 KM ..new engine
87 745 B230 non-turbo 250,000 KM (newest edition Jan '07)
86 244 GL B230 non-turbo 460,000+ KM
fredstock99
- Year and Model: 1993 850 GLT
I had a problem with my rear right window, took off the door panel, tested the motor, and wiring with a multi meter all the way back to the switch. Took my center consol apart to get at the switches, and figured I'd clean them with some electrical cleaner while I had it apart. After a good cleaning it worked fine again. Looking back, I'd try cleaning switches first, and then going from there.Have you dropped any coffee or other beverages on the unit recently?
1993 850 20 Valve 5 cyl : had 190k miles when i joined this forum : nor cal - so cal - long island. Now i live in NYC, its got 259k miles, and sadly, the only car I've ever owned is going to be scrapped. RIP Black Volvo. You will never be forgotten.
