What octane level should i use in my 94 850. ive been using regular. will using a higher octane lavel increase performance or will it just ruin my car. what is actually recommended by volvo.
-thanks
What octane level for gas?
- Has thanked: 17 times
- Been thanked: 35 times
Look in your owner's manual...it will tell you. If you have a non-turbo, usually regular is okay...if you have a low pressure turbo, then mid-grade. High pressure turbo's almost always use high octane.
KlubMarcus
- Year and Model: V70 XC, 1998
I use regular unleaded in a 1998 low pressure turbo V70 XC. Runs just fine. Maybe it's because I drive like an old woman.
I do agree that the high pressure turbo owners should use premium unleaded.
- Year and Model: Many Volvos
- Been thanked: 76 times
As was stated before, it depends on what engine you have. If you have a N/A motor a higher grade of gas won't do much for you in terms of performance. If you have a turbo, it will.but can i use higher octane gas to get better performance out of my car? or will this just mess up my car.
Under no circumstances, short of jet fuel, will running a higher octane fuel hurt your car.
In my case I actually get slightly worse mileage with "premium" as it is a 10% ethanol blend. The crazy thing is that premium sells at a 2 or 3 cent/gallon discount to regular in mid Missouri where I try to buy as much gasoline as possible. In the city they have some witches brew summer blend that is at least a dime a gallon higher than fuel out in the sticks.
thanks a lot for replys....i was just asking because my friend uses premium in his civic and says it makes a big difference....but i guess it will be the same for me...anyway, thanks for the responses..im beginning to learn a lot.
JRL
- Year and Model: Several
- Been thanked: 16 times
Well you should but seriously MIJ is right.hatalov wrote:wow, thanks for that...but i guess i should download it and read up on it.
Good rule of thumb in a Volvo is:
Regular for a non turbo
89 (or 91) for an LPT and always
PREMIUM in a high pressure. (T5, R, etc)
If your car has a modded chip (ECU) use the highest octane you can find as 93 will make a difference over 91, it's that close with these cars
Owners' manual should be with your car....usually glove box unless you don't have one for some reason, then you can download it from the Volvousa.com site- library section. You'll have to join up with personal information to access it.
- 56 Replies
- 16794 Views
Last post by vovo850
- 3206 Views
Last post by chris11211
- 810 Views
- 1736 Views
Last post by MadeInJapan
- 12 Replies
- 10606 Views
Last post by zanzabar
