98 S70 A/C clutch
john200981
- Year and Model:
The clutch on my A/C is about ready to let go....will work for an indefinate period, then air will get warm... I can turn A/C on then off right away and it will work again.....anyway..... how big a pain in the a** is it to remove and replace the clutch off of the compressor without removing the whole unit from the car? OR, is it even possible?
JRL
- Year and Model: Several
- Been thanked: 16 times
From what I understand I don't think it's possible, you need to replace the compressor.
If you were able to send it out to someone to just R&R the clutch, (if possible) the labor would get to the point that you may as well just replace the compressor.
CarVolvo
- Year and Model:
yes.. real pain to get to it. Even if you could replace the clutch assembly you need to remove the unit anyway.
Cross your fingers its not going to be hot and humid
THE FLEET!:
93 854 GLT 20v non-turbo 435,000 KM +
94 854 20v non-turbo 215,000 KM ..new engine
87 745 B230 non-turbo 250,000 KM (newest edition Jan '07)
86 244 GL B230 non-turbo 460,000+ KM
- Year and Model: Many Volvos
- Been thanked: 76 times
This problem is often related to the shimming on the clutch and is not a bad clutch at all. Here is a good writeup in checking and reshimming the clutch which can be done without completely removing the compressor or evacuating the system.
http://volvospeed.com/vs_forum/index.ph ... st&id=2323
Its worth a try.
Its worth a try.
john200981
- Year and Model:
Lee,Ozark Lee wrote:This problem is often related to the shimming on the clutch and is not a bad clutch at all. Here is a good writeup in checking and reshimming the clutch which can be done without completely removing the compressor or evacuating the system.
Its worth a try.
Can you recheck that link you added? It came up as a bad link.
john200981
- Year and Model:
Never mind.... it finally came up. My bad. LOL!john200981 wrote:Ozark Lee wrote:This problem is often related to the shimming on the clutch and is not a bad clutch at all. Here is a good writeup in checking and reshimming the clutch which can be done without completely removing the compressor or evacuating the system.
Its worth a try.
Hi,
Just did the clutch shim adjust to my '94 855t w/250k miles. It has worked like a charm so far. My local Volvo shop said the clutch electromagnet is bad, but it turns out that the gap has exceeded the capacity of the magnet to pull it in when the engine is hot. Restoring the gap to app. .015 by removing a shim or 2 does the trick. Mine was .030-.040.
Good Luck
Good Luck
john200981
- Year and Model:
Thanks! How long did it take you to do this work? Have never tried taking anything like this apart before....especially from below!rb2 wrote:Hi,
Good Luck
- 28 Replies
- 9101 Views
- 35 Replies
- 17246 Views
- 287 Views
Last post by skloon
- 496 Views
Last post by RobTheModd
- 89 Views
Last post by perhss70
