My transmission seems to hesitate before going into gear when I shift from park to drive. Could this be due to low fluid levels in the transmission? If so how can I add/check fluid levels? tranmission seems to run fine other than when shifting into drive. Any insight would be great.
thanks
2002 XC70 Transmission
JRL
- Year and Model: Several
- Been thanked: 16 times
You have to push the intake hose aside to find the hidden dipstick, then you should flush or at least drain and fill the transmission unless the fluid is red (which I doubt)!
Have the latest software installed at a dealer
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Moved for you - part of the moderator's job.I will move it.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
JRL
Transmission software.PittXC70 wrote:Thanks...I will take a look. Sorry for posting in wrong forum I will move it. You mention having software installed. What software would that be?
Volvo upgrades software usually every 6 months or so. There were at least TWO upgrades for 2002's
I had the software update recently performed. It is a huge improvement over the old sw. It will still jerk into gear in the morning unless I rev the engine a little in neutral before shifting into drive. All other issues are resolved. The shift flare is gone. The cold shift into drive problem is I believe one of the shift solenoids and should probably be replaced. I think I will just live with this issue as I don't think it will affect the performance or longevety of the trans.
- 16 Replies
- 15282 Views
Last post by vt9000cse
- 598 Views
Last post by precopster
- 911 Views
- 375 Views
- 1023 Views
