nlemerise over on Swedespeed shared this (also added to our database)...includes pictures...great write-up:
Inner and Outer Tierod End replacement tutorial
Inner/Outer Tie Rods DIY - S70, V70, 850, XC70
- Has thanked: 17 times
- Been thanked: 35 times
code-man850
- Year and Model: 855T '96
Yes I understand how it "should/would" come off. But I felt around for about ten minutes (thats a long time to feel around on one little part) and could not feel any flat spots anywere to fit a pipe wrench or any other wrench onto.
'96 855 Turbo
K&N, H&R, Mobile 1
Its a wagon thing...
You wouldn't understand.
K&N, H&R, Mobile 1
Timberwolf530
- Year and Model: 1994 850
If you're going to replace it with a new one anyway, just use a pipe wrench. You don't need flat spots. They're designed to turn round things. I've used them for that in the past and you get lots of leverage.
1994 850 Wagon - My car is on it's 3rd generation in my family. "I don't look at it as doing repairs, I see it as doing a complete restoration one part at at time."
code-man850
Ahhhh ohhhhh, gotchya. I'll be tryin that this weekend.
'96 855 Turbo
K&N, H&R, Mobile 1
K&N, H&R, Mobile 1
- Has thanked: 2854 times
- Been thanked: 1332 times
Fork in the road: Outer goes there, Inner stays here
Outer tie rod questions and tips on 850, S70, V70, XC70, and V70 XC older than model year 2001 let's put in Outer Tie Rod Replacement Tutorial - 850, S70, V70, XC70. Inner tie rod questions and tips we'll use this topic. It's not as though either inner or outer is that big of a job or terribly different from each other, but since we have two topics, might as well keep each focused. Thanks!
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 275 times
- Been thanked: 84 times
Just some info from my experience:
Tried to replace the inner tie rod today, but I utterly failed. Couldn't get the old one off - I tried a wrench (and hammering ist) and also a pipe wrench... no chance (not enough space and also the metal just strips off).
I checked online and there are special tools for this to use with an impact wrench... like this
At least I couldn't do it... so my advice - either get the tool or have the shop do it if you are not sure you can get it open.
At least I didn't ruin it.
850 T5-R '95 auto
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
Is the method in the video for inner tie rod applicable to 1997 850 with TRW rack?hausmeister wrote:Just some info from my experience:
Tried to replace the inner tie rod today, but I utterly failed. Couldn't get the old one off - I tried a wrench (and hammering ist) and also a pipe wrench... no chance (not enough space and also the metal just strips off). :x
I checked online and there are special tools for this to use with an impact wrench... (like this )
At least I didn't ruin it. :roll:
I don't know if my 850 has a TRW, but the problem was the same. I too used a pipe wrench. The tool in that video looks like a lot of work to save a little work.
xHeart
I am faced with same. But havn't given up yet. A good rest is what I need first.hausmeister wrote:Just some info from my experience:
I am trying to source the boots in order to do this repair. I need the SMI boots (Volvo P/N 9191409). It appears that the only name-brand aftermarket for these is "KARLYN." Has anyone ever tried the KARLYN brand boots? Are they any good?
I'm seeing a 2 pack of KARLYN for about $30 on eBay vs $46 each for Genuine Volvo at TASCA.
