The other day my c70 started missing for about 10 seconds, the check engine
light came on and the it stopped missing.
When I got home I connected a laptop to the OBDII connector with a DigiMoto unit I have, the fault code was Misfire on cylinder 3.
I replaced all the plugs the next day, started driving to work and it started missing again, then ran normal, I pulled over and hooked the laptop up again.
This time the code said Misfire on multiple cylinders.
Does anyone have a suggestion as to what the issue might be?
Distributor perhaps?
Just a note, I did have the ECU flashed a couple months ago for the recall, and apparently mine was affected because it was surging.
1999 Volvo C70 Conv, 66K
Thanks for any help!
99 C70 Misfire
- 19 Replies
- 10382 Views
Last post by Barledge
- 3024 Views
- 34 Replies
- 2116 Views
Last post by Gregory91PL
- 1905 Views
Last post by precopster
- 1652 Views
Last post by bmdubya1198
