hello fellow volvo owners. anyone know how to replace the blue led (assuming led) indicator light that is illuminated when turning on the A/C?
the a/c works just fine but the light no long comes on when the a/c is turned on. just a moderate annoyance.
couldnt find any links on the web that shows how to remove the climate control panel to change these lights.
thanks.
960 A/C Button Light/LED Replacement
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
I think it is a bulb rather than a LED and it is my understanding that the blue light should come on when the A/C is switched off i.e the button is depressed.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
ummmmm dont think so. why would the light go off when the A/C is turned on? maybe you just typed it wrong. buttin pushed in makes the a/c blow cold. button in the out position (sticking out) turns off the a/cbillofdurham wrote:Welcome to Matthew's Volvo Site.
Bill.
regardless, I need to know how to change the light. thats all.
- billofdurham
Only if the Owner's Manual has got it wrong.maybe you just typed it wrong
I am still researching how to change the light.
Bill.
Previously:
Previously:
- volvoaddict007
- Year and Model: 760 Turbo
My '90 760 ECC has the "snowfllake" graphic ( instead of A/C OFF ) and the light comes on when air is on...
IT'S A CONSPIRACY !!!
Anyhoo, poor dbrahms just wants to know how to change the friggin bulb or LED or whatever the heck it is. I would suspect a bulb. What year's the 960? Maybe someone changed out the ECC.
1990 5 speed 760 Turbo Wagon 310K.
( '91 940 turbo eng. + trans.)
Konis, diesel springs, 2.5" exhst., 850 T5 wheels
1993 300ZX 2+2, 171K
1999 Ford Windstar LX, 90K
- billofdurham
To remove the control unit gently prise off the plastic surround to locate four torx screws. Remove the screws and slide the unit out of its housing. Remove the two wiring plugs from the rear of the unit.
You should now see 6 lamps in the control module. The lamps can be changed without removing the unit cover.
Bill.
Bill.
Previously:
Previously:
- 1303 Views
Last post by oizdaman26
- 1236 Views
Last post by Vova585
- 846 Views
Last post by NickA
- 690 Views
Last post by MadeInJapan
- 2502 Views
