Hi Everyone,
This is my first time on this site...and the reason I started searching the web is because I'm have a problem with my 99 S8 T6. I've had it for almost 3 years...it has about 77K miles on it. I haven't had any problems with it until now.
I'm from the Boston area...and if any of you haven't heard....we're having a freezing winter. Anyway, one morning, I'm warming up my car and the Engine System Service Urgant light went on. I drove to work and decided to check my oil when I got there. Sure enough I'm super low. I haven't had an oil change is a long time because a Jiffy Lub wont touch a Volvo Turbo and it's a 2 day project to get it done at a dealership. I filled up the oil then made my appt. with the dealership.
4 days go by...everything is running great...I'm not seeing any freakish lights turning on in my car, until one night, as I'm driving, the Engine System Service Urgant comes back on. I decided to slow down, and that's when I realized my breaks were gone. I shut my car off for about 5 min. and when I turned it back on, everything was fine.
Has anyone had any problems with that??
Now that I babbled for 10 min. let me get to the point of why I am emailing in. A friend of my husbands, sister owns the same year and make of my car and she brought it in because she was hearing a weird noice on the front end...which I hear also. They told her it was a re-call that was basically a word of mouth type thing....they said that this was a re-call that they didn't send mailers out for.
I asked the dearlership...not the one she went to, if there was a re-call and they said no. Has anyone heard of this for the 99 S80 T6.
Thanks for reading
Cynthia
S80 T6 Recalls....anyone know of any???
- Has thanked: 2854 times
- Been thanked: 1332 times
nightshift
- Year and Model:
Hope this helps.
Note TSB means "Technical Service Bulletins)
Bulletins for 1999 Volvo S80 T6 L6-2798cc 2.8L Turbo B6284T 24V
Safety Recalls
TSB Number Issue Date TSB Title
1. 08111 JAN 03 Recall - Trailer Hitch Defect
2. 26110 APR 02 Recall - Engine Cooling Fan Replacement
General Recalls
1. 3300001 JUL 01 Campaign - Transmission Control Module Software Upgrade
2. 6199 SEP 00 Campaign - Ball Joint Durability Concern
3. 6610006 SEP 00 Campaign - Ball Joint Replacement
Service Bulletins
1. 2210040 APR 03 Engine - In-Car Piston Replacement
2. 4430027 JAN 03 A/T - Upshift Shudder
3. 3360022 OCT 02 Wipers/Washers - Wipers Shudder/Noisy
4. 3390034 AUG 02 Interior/Audio System - Dash Speaker Grille Removal
5. 8870023 APR 02 A/C - Recirculation Door Air Leakage
6. 6650003 MAR 02 Dirt Deflectors (Rear Wheel) - Installation
7. 00205 OCT 01 Interior Safety Products - Reuse/Disposal
8. 4430032 OCT 01 A/T Gear Selector - TCM DTC 0094 Stored In Memory
9. 3370007 OCT 01 Engine - Hard Start/Tachometer Jumps/DTC Set
10. 2280011 OCT 01 Engine - Long Cranking/DTC Set/Tachometer Jumps
11. 2250023 JUL 01 Electronic Throttle Module - Uneven Idle
12. 3390025 JUL 01 Radio - Interference/Noise On AM Band
13. 2250025 MAR 01 Turbocharger - Oil Delivery Pipe Replacement
14. 4430017 FEB 01 A/T - Diagnosis & Check List
15. 0097 JAN 01 Lemon Laws - Repeat Repair Procedures
16. 3390018 JAN 01 Radio - AM Reception Diagnostics
17. 2230052 NOV 00 Fuel System - Quick Release Connector
18. 8850014 OCT 00 Power Seat - Movement on Acceleration/Deceleration
19. 8840029 AUG 00 Body - A Post Lower Trim loose
20. 881A JUL 00 Seat Belt - Extensions
21. 6610004 JUN 00 Special Tool - Ball Joint Removal/Installation
22. 5510005 APR 00 Rear Brake Pads - Vibrations
23. 2210030 APR 00 Subframe Bushing - Knocking Noise
24. 4460003 MAR 00 Drive Shaft Viscous Coupler - Seal Replacement
25. 8830031 FEB 00 Power Window Regulator, Front - Updated Replacement
26. 3390010 FEB 00 Radio - Noise Interference on AM Band
27. 43-0026 JAN 00 Automatic Gearbox - Installing Additional Guide Sleeve
28. 250018 DEC 99 Heated Oxygen Sensors (H02S) - Replacing
29. 350009 NOV 99 Hi Mount Brake Light - Replacement
30. 4430013 SEP 99 A/T - Shift Lever Replacement Procedure
31. 2230038 JUL 99 Fuel Cap Seal - Testing
32. 223 OCT 98 Engine Oils - Recommended
33. 00192 OCT 98 Maintenance - Interval Schedule
34. 0097 JUN 98 0097 - 06/01/98
Safety Recalls
General Recalls
Service Bulletins
- 1326 Views
Last post by vjaneczko
- 1026 Views
Last post by Steve H
- 822 Views
Last post by hypo
- 13 Replies
- 6042 Views
Last post by esl_97_850_T5
- 1393 Views
Last post by bmdubya1198
