Hello all, I am new here and a new owner of a 1996 850 Volvo (136000+ miles). This is my first Volvo.
My question: What is the typical rpm at idle?
Thank you in advance,
Sliderule
Typical rpm at idle
- Year and Model: Many Volvos
- Been thanked: 76 times
It depends on how much attention was paid to the needles when the odometer gear was replaced. I didn't pay any attention and mine is 0 RPM.
Someday I will fix that as well as the 3 mph difference in my speedometer.
It varies depending on if you have an automatic or manual transmission but it should be around 750 RPM.
Thanks Lee, btw I should have included that it is an automatic.
The reason I asked is because the tack is reading zero at idle and this is after a mechanic looked into the issue of my odometer not rolling over. He told me that the "gear" was okay and that it was the motor, in the odometer. Does that make much sense to you?
Sliderule
Sliderule
CarVolvo
- Year and Model:
either way your going to have to remove your speedometer unit to check it out. So why not just remove it and see if the gear is broken or you need a new motor for the odometer?
Actually it sounds like something is up with your cluster if your having problems... you might want to check the rpm sending unit as well as the wires to the cluster .. perhaps just getting a replacement cluster unit might solve a few problems for you.
BTW my rpm is usually just under 1,000 on idle
THE FLEET!:
93 854 GLT 20v non-turbo 435,000 KM +
94 854 20v non-turbo 215,000 KM ..new engine
87 745 B230 non-turbo 250,000 KM (newest edition Jan '07)
86 244 GL B230 non-turbo 460,000+ KM
The specfication is 850 rpm, yes for the 850
. There is a emissions label under the hood (on the hood near the passenger side) that should state the idle RPMs, which every car has.
According to my car's computer (reading it with a scan tool) my computer says 840, but thats pretty darn close.
I have encountered a situation where the cluster doesn't report the correct RPM at idle and at idle only... but the car's computer reads the correct RPM... i've seen this problem on my uncle's S70 where his cluster reads 1000, but my OBDII scan tool is reading 850 from the computer.
1998 Volvo S70 T5 Auto
1995 Volvo 850 GLT <- RIP
MadeInAmerica
- Year and Model:
Yes this is true. The gauge is not accurate below 1,000 when at idle. If you looked at my gauge you would say the idle looks like 950 when the spec is 850. I found my car was doing 850 at idle when I got my emmissions done and I could see the number on the screen . In other words my car was accurate at 850 but the way the gauge looks , the gauge is not accurate.kelvin6 wrote:The specfication is 850 rpm, yes for the 850.
'94 850 Turbo 160K Automatic
[Autometer Sport/Comp Boost Gauge][Silicone Vacuum Hoses][Walbro Fuel Pump][New OEM Torque Mount][Yokohama YK520][New PCV system+Air Intake Hose][Magnaflow Cat at 160K][Borla Pro XS Muffler 162K]
- 3747 Views
- 13 Replies
- 3481 Views
Last post by 800artfreed
- 590 Views
Last post by Clemens
- 946 Views
Last post by arvik
- 465 Views
Last post by Jonboy74
