Hi,
I just put new struts/mounts/control arms/tie rods ends on my '96 850.
Basically replaced everything I could, used OEM struts etc.
I took it to Midas for an alignment and after looking at the paperwork this is what they wrote:
"right front camber not adjustable, would need to get strut mount adjusters, also right rear toe off, would have to install shim."
I'm a little lost here...is there a reason they couldn't do this? I don't understand...everything is brand new!!! Should I have taken it to the volvo dealer instead for the alignment?
New struts on 1996 850 now can't get alignment ?
Volvo Wheel Alignment Order
drumsagogo
- Year and Model:
- Year and Model: Many Volvos
- Been thanked: 75 times
IPD sells a camber kit to increase the factory camber range.
IPD Camber Kit
On the rear toe they simply don't know what they are doing. The rear toe is adjustable without shims. It is important that the car be aligned in this order:
Rear Toe
Front Camber
Front Toe
Otherwise they will just chase their tail.
IPD Camber Kit
Rear Toe
Front Camber
Front Toe
drumsagogo
- Year and Model:
thanks for the reply.
maybe I should just install it the kit on the right front side and take it to the dealer for the alignment? or might the dealer install the kit?
I don't think i'll take it back to midas.
The dealers actually have their own version of the kit if you actaully do need it.
- 1024 Views
Last post by shegarty
- 1911 Views
Last post by Steve Ivins
