Hi All,
Just purchased a 96 850 GLT, and am checking it out for all the obvious problems. Apparantly, the flame trap was not changed on a regular basis, it was pretty clogged up so I replaced it. The Vacuum line connection that connects to the flame trap had turned to goo. I realize I probably should rebuild the pcv system, but cannot afford that just yet. Can this tube be replaced without removing the intake, or should I try splicing into the current hose to get me by a while.
thanks all
Chris
Flame Trap vaccum line
jchrisloyd
- Year and Model:
2002 Volvo S80 2.9
1996 Volvo 850 GLT
1996 Volvo 850 GLT
- Year and Model: Many Volvos
- Been thanked: 76 times
Chris,Can this tube be replaced without removing the intake, or should I try splicing into the current hose to get me by a while.
If it is the line I think you are talking about, I don't think so. The part is available as single item but you will also need and intake gasket. Check the diagrams at FCP Groton.
Hopefully "a while" is a short while. A clogged PCV system = a blown rear main seal.
jchrisloyd
- Year and Model:
Thanks Lee,
I was able to tear into the car this weekend, and realized that the line coming to the flame trap was a hard line, and that what had turned to goo was a rubber connector that connected to the hard plastic line and the flame trap. I replaced the rubber connector, and the pcv system seems to be working fine now. The car passes the smoke in the dipstick tube test, as well as the oil cap is now easy to remove after shutting off the engine.
At 130K i still need to plan on replacing the pcv system, but at least now i can plan the job.
Thanks again
Chris
Thanks again
Chris
2002 Volvo S80 2.9
1996 Volvo 850 GLT
1996 Volvo 850 GLT
- 1033 Views
Last post by smeha
- 1718 Views
Last post by 93Regina
- 2669 Views
Last post by jblackburn
- 725 Views
Last post by Ozark Lee
- 13 Replies
- 4434 Views
Last post by erikv11
