Went to a website to look up codes for my car and it has 3 different types of systems listed--Fenix 5.2, Motronic 4.3, Bosch LH 3.2 Jetronic systems.
How can you tell which one is on the car? The codes listed on this website are different than the ones off of Bay 13.
Just curious...
ancv
code box questions, 93 850 glt
CarVolvo
- Year and Model:
you have to know your engine type to determine this.
Motronic 4.3 installed on turbocharged units and some non turbo b5254 s engines. Its similar to the jetronic but it uses a single ECU to control the fuel and ignition.
Motronic 4.4 installed on 1996 and 97 b5254s.
Fenix 5.2 is the one used on the 10 valve non turbo engines and also uses a single ECU for fuel and ignition.
And then there is the jetronic by baush..
THE FLEET!:
93 854 GLT 20v non-turbo 435,000 KM +
94 854 20v non-turbo 215,000 KM ..new engine
87 745 B230 non-turbo 250,000 KM (newest edition Jan '07)
86 244 GL B230 non-turbo 460,000+ KM
CarVolvo
- Year and Model:
why not just give us a vin number or secondly go to your library and look up a volvo repair book by haynes.
Usually the number is on the timing belt cover on the engine itself.
But if you have a 93 its most likely jetronic.. first year of the car and not too many options available for drive trains.
THE FLEET!:
- 1916 Views
Last post by subzerocarfanatic
- 223 Views
- 210 Views
Last post by koralski
- 3026 Views
Last post by InsanitySpark
- 2294 Views
Last post by 93SCMax
