1992 940 turbo stalling then starts runs fine
petek153
- Year and Model: 1992 940T
Just had my first problem with our 940 turbo. After a 30 mile trip the car acted like it was running out of gas,tach ,turbo guage , trouble lights went nuts.lost all power. Shut off ignition and then restarted car and ran as if nothing was wrong. This is the wifes car and hate to have her get stuck with a break down. Any ideas what causes this to happen? Car has 140,000 on it and is young for a Volvo. This happened last week and as of yet hasn"t happened again yet.
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Have you checked for fault codes?
You can do this yourself on the 940 using the on-board diagnostics.
A full how-to can be found at:
https://www.matthewsvolvosite.com/chat/p ... c&start=12
It is headed for the 740 but it applies to the 940.
Post any codes you find for more help.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
outofworkjoe
- Year and Model:
My 93 940 turbo acted this that had to replace the Ignition Amplifier (Power Stage) on the rt finder wall,Allso and dieing fuel pump relay will act that this.Heres is the Ignition Amplifier: http://img146.imageshack.us/img146/5294 ... agewg6.jpg
1991 volvo 240 207000 my car/1993 volvo 940 turbo 160000 wife/1989 245 267000 sons
petek153
Final as to what problem was . The turbo air cleaner box was lined with a foam substance, I think for sound deadening it had started to fall apart and actually blocked air flow through the MAF looking in the screen was mostly blocked. Trying to go pulled more into what was left not blocked and would kill the engine.Removed blockage and the rest of foam from air cleaner area .Car now runs great.
- billofdurham
Some 'major' problems have easy and inexpensive solutions.
Good to know you fixed it and thank you for the update.
Bill.
Bill.
Previously:
Previously:
- 1936 Views
Last post by volvolugnut
- 3122 Views
Last post by bharman
- 1260 Views
Last post by RickHaleParker
- 2145 Views
- 1189 Views
Last post by dosbricks
